Thread: KIND of Dumb NEEd heLP !!
Results 1 to 10 of 10
  1. #1 KIND of Dumb NEEd heLP !!
    new york
    Hey i was replacing my coolant fluid and went to pull out the coolant plug on the bottom of the radiator and noticed that the top half that help you get a grip on turning the plug chipped off. I tried getting all kind of pliers in and around it and also drove a flathead screw driver right into the center to try and screw it out, all failed. Is there any other method that i can use that will not hurt my radiator. Thanks !
  2. #2 Re: KIND of Dumb NEEd heLP !!
    GTX Level Member cerick08GP's Avatar
    I have heard from several other people the same problem. The drain plugs don’t open properly, and even if they do, they are prone to being clogged.
    Imo, return the drain plug to the closed position, then remove the lower radiator hose to drain your system.
    Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: KIND of Dumb NEEd heLP !!
    new york
    Ya i did that last night, id still like to get the plug out
  4. #4 Re: KIND of Dumb NEEd heLP !!
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    When I broke a drain plug (petcock) I used a grab-it (easyout's, etc) drill thing and then just bought a new one, but had to get one online since no store around me had one.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  5. #5 Re: KIND of Dumb NEEd heLP !!
    Guam
    There is no room to drill, room is limited. I had an issue as well, there was nothing to grab on to, I boguthmy car used, so who knows what happened. I ended up using pliers to turn it and did not damage it. Once out, you can find them at local auto stores.
  6. #6 Re: KIND of Dumb NEEd heLP !!
    its so much easier just to pull the lower coolant hose.
  7. #7 Re: KIND of Dumb NEEd heLP !!
    Jersey
    I got mine out just fine with pliers.
    16' wrx sti- stock
  8. #8 Re: KIND of Dumb NEEd heLP !!
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i have ran into this problem on several cars. you are limited, pliers or sum kind of grab and turn, once you turn these things u got to sort of wiggle and pull straight out, it will drain. if you want the whole piece out it should keep comming straight out after the first initial turn. i have been succesful with my small vise grips, not really clamping on the drain peacock handle but just open enough to slide in there and turn. i have had to BREAK these out carefully. u may have a small end piece that stays in the system but what are you gonna do? replace it and you are done. if all else fails you have to remove the radiator, or remove something else to gain access. good luck. ps remember its only plastic.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  9. #9 Re: KIND of Dumb NEEd heLP !!
    Cleveland Ohio
    I must have been lucky then, becuase I didn't have to drill the one I broke. It was hollow, so I just put a grab-it in there with my hands then just got pliers and turned the bit and it came out with no issues.
  10. #10 Re: KIND of Dumb NEEd heLP !!
    I need your help too.. please don't type the title in a way that makes me want to skip by the thread.
    Some draincocks aren't intended to come out, some are. New ones are usually available at local parts stores.
  1. I'm pretty sure You will think this is dumb
    By Red97GPGT in forum Visual/Body Modifications
    Last Post: 04-02-2009, 12:36 AM
  2. I have a dumb tranny question regarding the pan....
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-05-2009, 11:52 PM
  3. Another Dumb@$$ for you
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 10-20-2008, 07:52 PM
  4. dumb q
    Last Post: 06-07-2008, 01:09 AM
  5. Dumb question (Oil)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2008, 12:10 PM
