Thread: Sythetic VS Regular 5W30
Results 41 to 60 of 83
  1. #1 Re: Sythetic VS Regular 5W30
    SE Level Member Fubisin's Avatar
    London, ON
    Thanks guys for the posts, I have once again learned something new. I have always just taken my cars into a one stop shop and gotten the oil drained and whatever the cheapest oil is, it goes in. Keeping in mind I have never own a new car in my life. Now I am alittle more anal about this one.
    Money really isnt an issue for me, especially when it comes to a $20 oil change or a $50 oil change, pennies are pennies, but if the warranty requires me to drain every 5000K, then putting a fully synthetic in would be pointless. When my warranty runs out next year and I have to choose from a oil the obvious choice would be synthetic, RP or Lucas. Higher cost of oil but lower than repairing an engine.
    I want to thank BlueGTP, sabrewings, JJR for there input.
  2. #2 Re: Sythetic VS Regular 5W30
    Oct 2008
    Northern Illinois
    No matter what anyone says, even with synthetic I still change every 4k.
  3. #3 Re: Sythetic VS Regular 5W30
    MN
    The way I see it, all synthetic motor oils are the same... Think with your dipstick JIMMY!!!
  4. #4 Re: Sythetic VS Regular 5W30
    SE Level Member m3ta77ica's Avatar
    Illinois
    ha ha love that commercial.
  5. #5 Re: Sythetic VS Regular 5W30
    Barksdale AFB, LA
    Bob is the Oil Guy is a pretty decent site, but whether intentional or not has some misinformation. Your best bet is to talk to someone who works in an analysis department and get your info from the horse's mouth.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Sythetic VS Regular 5W30
    MN
    Yeah I do too. I'm sure everyone knows that synthetics are better for wear resistance, better performance, and a cleaner engine. But like they said, you pay for it.
    Anyone heard of pennzoil adding wax to their conventional oil. Engines that run those are stained gold inside! So there are better brands. Now that's thinkin' with your dipstick!
  7. #7 Re: Sythetic VS Regular 5W30
    Barksdale AFB, LA
    Here is what my engine looked like after running RP for only a little over a year. Clean:
    My STI is getting the same treatment.
  8. #8 Re: Sythetic VS Regular 5W30
    Oct 2008
    Northern Illinois
    Royal Purple is nice, but Mobile 1 is good enough for me. It's still awesome oil.
  9. #9 Re: Sythetic VS Regular 5W30
    Oct 2008
    Northern Illinois
    For a high-mile car would youguys say Valvoline MaxLife synthetic blend or mobile 1 is better?
  10. #10 Re: Sythetic VS Regular 5W30
    May 2008
    Winnipeg, MB
    I'm using amsoil 5w30 and amsoil oil filter, going by the oil life indicator in the DIC, once it tells me its time to change oil I will, not before. I will send the old oil to blackstone labs for anaylisis and post my results
    2007 Pontiac Grand Prix
  11. #11 Re: Sythetic VS Regular 5W30
    Oct 2008
    Northern Illinois
    Quote Originally Posted by tod1d View Post
    Yeah same here I go by the DIC not miles.
  12. #12 Re: Sythetic VS Regular 5W30
    Joliet, IL
    Quote Originally Posted by BwolfGT View Post
    go by miles the DIC is off and a piece of shyt...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  13. #13 Re: Sythetic VS Regular 5W30
    May 2008
    Winnipeg, MB
    Quote Originally Posted by BoostJunki3 View Post
    tell that to GM and see what they say
  14. #14 Re: Sythetic VS Regular 5W30
    Barksdale AFB, LA
    Incorrect. GM spent millions of dollars developing the oil life monitor. Lots of oil analysis done examining factors like engine load, engine temp, operating time, mileage, etc. It's quite accurate. I had my analysis done on some dino oil when the oil life monitor said about 10%, and the analysis agreed. It can be trusted.
  15. #15 Re: Sythetic VS Regular 5W30
    Joliet, IL
    Quote Originally Posted by Sabrewings View Post
    ive heard different but your a pretty knowledgeable guy so i guess i stand corrected
    00 Silvermist GTP
  16. #16 Re: Sythetic VS Regular 5W30
    Barksdale AFB, LA
    Anyone who thinks differently should present the analysis reports. Most people don't trust it because they don't know oil and don't understand how the OLM works.
  17. #17 Re: Sythetic VS Regular 5W30
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    DIC oil monitoring system is not accurate. It might be for conventional, but definitely not Synthetic. I ran 8k on my 2nd to last batch of Mobile 1 EP and my OIL Analyzers report showed a high silicone content. This was do to my K&N air filter ripped against my PCM. I have since replaced that filter with a new AEM dry flow and Ran Mobile 1 EP around 12k and it was time for an oil change based off my OIL ANALYZERS REPORT.
    This is who I use
    Oil Analyzers, Inc. - Analysis Program Details
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  18. #18 Re: Sythetic VS Regular 5W30
    Barksdale AFB, LA
    Quote Originally Posted by JJ91284 View Post
    It's not going to detect a problem like your air filter. It has no sensors or anything of that sort. It simply measures engine load, engine temps, RPMs, mileage, etc to determine when the oil should be changed. If your air filter is messed up that's your own fault.
    It also assumes you're running dino oil so for synthetic users when it goes off you could most likely go longer. The OLM is no replacement for real analysis though.
    Quote Originally Posted by felonygtp View Post
    I don't really care what people in a lab say about how good a oil is. I see what happens in a race engine when Royal purple is used.
    Your motor looks clean inside so I assume it was treated decent. I'm sure your engine isn't turning 6000-7000 rpm almost every minute of it's life. I don't remember the last time I started my pull truck motor to hook to a sled and go for a Sunday cruise, down by the lake.
    To be fair, most professional racers do not use any off the shelf oils, including synthetic. Normal every day automotive oil is not intended for those conditions. So calling out one brand because it doesn't work properly in conditions it wasn't designed for is a little outside reason.
  19. #19 Re: Sythetic VS Regular 5W30
    Jan 2009
    Tabor SD
    [/QUOTE]To be fair, most professional racers do not use any off the shelf oils, including synthetic. Normal every day automotive oil is not intended for those conditions. So calling out one brand because it doesn't work properly in conditions it wasn't designed for is a little outside reason.[/QUOTE]
    Royal purple claims to be high performance. Brad Penn Grade 1 is high performance yet one works fine in race engine and the other doesn't why is that? Royal purple has a Race oil line and it doesn't work any better than its off the shelf brother.
    Castrol SYNTEC = driving in extreme climates (frigid winters/scorching summers)
    Castrol GTX = driving in moderate climates
    Redline = racers
    I'm thinking about trying that redline oil in my SBC there has been alot more guys running it in there alcohol motors. Its fresh this year and its cheap to rebuild if it doesn't work and its easier to get. I have to order Brad Penn oil and I hate having to have two cases on hand at all times because both motors take different oil.
    I run 10w30 year around I probably should run 5w30 but I hate switching. My oil cap says 10w30 so I guess that's what I'll run. It seems like it can go from -30 to 100 in the same day in South Dakota, two weeks ago it was 70 and now there's snow on the ground.
  20. #20 Re: Sythetic VS Regular 5W30
    Schaumburg, IL
    I never said it DIC used your airfilter for estimating how much time you have left on your oil. I used that as an example of why an oil analysis report is nice to have done, because I probably would not have caught that until I cleaned my air filter. I own a DHP powertuner and I can purposely mess around with the oil life system by throwing off my tune. GM just used the oil monitoring system for normal dino oil and never designed it for synthetic. Lets not also forget oil technology has changed in the last 12 years since my GTP came off the showroom floor.
