Can I put a 04+ gxp motor/trans in a 97-02 grand prix? Cuz I wanna get a cheap gt/gtp coupe and swap a gxp motor/trans in it.
Cheap can't be used in the same sentence as a LS4 swap into a 97-03 W Body.
If money isn't an option you could put a v16 in there lol but actually i'm not joking. Anything can be done with enough $$$
Sure you can do it. It will require some modification for engine mounts and I'm sure some other things. Also to let you know that there is not much support for the LS4.
I just like the sound of then v8 but down the road I would throw a turbo n be done with it im not lookin to race it, jus to have it.
I was also wondering if a LS1 would mount up with a LS4 trans?, cuz if so I would try that set up if it would work
The LS1 would have to be extensively modified to make it work. Look at the info in this article where GM put an LS1 into an Impala. Some of the modifications to the LS1 are mentioned.
LS-1 Powered Impala SS - Feature - GM High-Tech Performance
yep... one of the guys who swapped an LS1 into a GTP was Tom Killgo. They had to do alot of custom work on the front cover. Its together and running, don't know what happened to it since. Loyde from Fast Fieros did the swap and fabbing on that car. IIRC it was stroked and bored, headed and cammed. Sounded pretty nasty from what i've heard. If it was my car, I would of just switched it to RWD, I think it would of been easier in the end...
LS4 swap shouldn't be that hard on a 97-03.... You could probably used off the shelf parts such as mounts and CV joints to make it work. Bolting it in is the easy part, hard part would be the wiring itself. I think to do an L67 swap in a Pre-Gen there is a 100 wires you need to splice from the firewall to the engine harness.
If you're gonna do it, get a complete drop out from a GXP, subframe, motor tranny, CV joints, complete harness, etc etc.
