toolguy
I have the same issue on my passanger side and am fixing it now. The issue is the actuator, basically a motor with gears, that moves the temperature blend door to create hot, warm, or cool air is not working and must be replaced.
The part is not cheap if you buy new, I found $112 on ebay. It is easy to get to, just remove the glove box, for the passenger side. If it is your driver's side, it is a little more buried but still can be accessed.
You stated passenger side blows warm, then driver's side blows warm in your post, so I am not certain which side has the issue.
