Thread: clunk going into reverse????
Results 1 to 17 of 17
  1. #1 Re: clunk going into reverse????
    Oct 2008
    Northern Illinois
    Quote Originally Posted by vader99 View Post
    Okay guys....I popped the hood and got in the car and started it up and then watched through the windshield as the engine jumped as I put the car in reverse. It definitely jumped and made the clunking noise while doing it. So, this means some mounts are bad, correct?
    Now, are worn dog bone mounts capable of allowing the engine to jump that much or would the lower mounts more than likely be the culprit(s)?
    I went to the local GM dealer up here in Canada and they wanted approx. $800.00 for all four mounts. I definitely don't want to spend that much if I don't have to so I would like to try to eliminate some from the situation if I can.
    thanks...
    You can get normal upper mounts for like 30 bucks, or ZZPs polyurathane mounts are only 60. Lower mounts are even cheaper. Dealerships are ****ing retarded.
  2. #2 Re: clunk going into reverse????
    Canada
    Quote Originally Posted by BwolfGT View Post
    Okay, great. Now exactly where can I get these cheaper factory mounts from for the top and bottom that you speak of? Those prices are more in line with what I thought they should be. Sorry for the questions but I am new to the grand prix scene.
  3. #3 Re: clunk going into reverse????
    Oct 2008
    Northern Illinois
    Auto Parts Fast at RockAuto
    They're I think $28.99 or something like that from there for stock replacements.
    Or if you're into modding you can get these ones from ZZP for $59.99
    ZZ Performance
  4. #4 Re: clunk going into reverse????
    Canada
    Should I replace the upper mounts as well, or just the lower ones?
  1. clunk in steering wheel
    By fluffy54935 in forum General Tech Discussion
    Last Post: 11-12-2010, 03:58 PM
  2. weird clunk
    By MikeGTP88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 04:13 PM
  3. Clunk from diff going into reverse
    By TZFBird in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2009, 10:02 PM
  4. Pop/Clunk Sound
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2008, 02:59 PM
  5. 2004 Grand Prix GT suspension clunk
    By McVaaahhh in forum General Tech Discussion
    Last Post: 04-19-2008, 01:04 PM
