Thread: stuck in dallas
Results 1 to 5 of 5
  1. #1 stuck in dallas
    Omaha, NE
    so i drove down to dallas yesturday from omaha nebraska and half way here i added 6 gallons of 89 octane and shortly after that it started missing and hessitating realy bad and i was told it was because i had a 3.4 pully and ran lean so i ran it low on fuel and filled up with 91 octane and octane booster well it was still doing it so i filled up once again with 93 and it used to only do it under wide open throttle and i check the codes it says missfiring in cylinder 4 so i have changed the sparkplugs and the wires and the coilpack and i did a fuel check and it never got 40psi so only opton i can think of is bad fuel injector? anybody have any ideas, im here visiting famiy and limited on tools and time before i have to drive 600 miles home need advice please
  2. #2 Re: stuck in dallas
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    my advice, just stay there. its GOTTA be better then where you came from (i live 35 miles north of you)
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: stuck in dallas
    Moore, Oklahoma
    never got over 40 psi? Same with driving as well? If so you're fuel pump is gone... I had the same issue on my black car
    Shawn W. Larsen
  4. #4 Re: stuck in dallas
    Omaha, NE
    Back in NE now
  5. #5 Re: stuck in dallas
    Nov 2008
    Fremont Nebraska
    so what was the problem?
  1. Hello From Dallas
    By DallasBill in forum Introductions/Noob Questions
    Last Post: 08-25-2009, 11:53 PM
  2. LIM replacement needed in Dallas
    By DallasBill in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 06:46 AM
  3. stuck in a rut
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 12:50 AM
  4. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
  5. Hello Everyone from Dallas and Help!!
    By GTPOWER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 10:22 AM
