Thread: all issues fixed :)!!!
Results 1 to 11 of 11
  1. #1 all issues fixed :)!!!
    Joliet, IL
    wow guys you'll never guess the culprit....my bottom coil pack was wrong....it must have been from my old grand am gt 3100 i have alot of coils laying around the garage because the 1 and 4 on the coil were opposite the one is supposed to be on the bottom and 4 on top and it was vise versa must have accidently grabbed the wrong coil during one of my engine bay painting projects ....so in other words....cylinders 1 and 4 were firing out of order....now that its corrected.....0.3 kr is all i see throughout pulls and it pulls like it should
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: all issues fixed :)!!!
    Banned - Busted For Scamming
    Feb 2009
    If it were still on the same coil, wouldnt have mattered seeing how its a waste spark system. You probably had corrosion or a loose plug wire.
  3. #3 Re: all issues fixed :)!!!
    Joliet, IL
    coil tested bad at advance auto just got back i wanted to know for sure under high load it didnt even fire at all...
    00 Silvermist GTP
  4. #4 Re: all issues fixed :)!!!
    Charles City, IA
    Thats just what I was going to say
    SMGPFC Two Nipple General
  5. #5 Re: all issues fixed :)!!!
    Feb 2009
    Well there is your problem. Knew it wasnt the wires. If you had a scope you could have figured that out already.
  6. #6 Re: all issues fixed :)!!!
    Charles City, IA
    Might not have seen it since it happened under high load.
  7. #7 Re: all issues fixed :)!!!
    Donating Users Liquifire's Avatar
    Wausau, WI
    congrats...glad you finally got it figured out.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  8. #8 Re: all issues fixed :)!!!
    Joliet, IL
    thanks for all the potential idea, help guys its appreciate it so glad it wasnt anything serious....and i hope my last drive/pulls werent a fluke lucky run
    00 Silvermist GTP
  9. #9 Re: all issues fixed :)!!!
    Feb 2009
    Sure ya can. Log it while you drive it hard and you can review the captured data.
  10. #10 Re: all issues fixed :)!!!
    now thats just a silly thing to do. you need to be more organized when youre working on your car, guy.
  11. #11 Re: all issues fixed :)!!!
    Joliet, IL
    hey we all make silly mistakes sometimes
    00 Silvermist GTP
  1. How can this be fixed?????
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-14-2009, 08:18 PM
  2. Fixed my Exhaust
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2009, 01:54 AM
  3. Got car fixed what to watch out for next?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 05-10-2009, 06:45 PM
  4. Can this be safely fixed?????
    By YoungGTP in forum Visual/Body Modifications
    Last Post: 11-10-2008, 11:24 AM
  5. Never Got It Fixed
    By offroadfury6 in forum General Tech Discussion
    Last Post: 10-02-2008, 06:07 AM
