Thread: Multi Function Switch
Results 1 to 3 of 3
  1. #1 Multi Function Switch
    SE Level Member N8Dogg98's Avatar
    Brooklyn Center, MN
    Hello everyone, I recently acquired a 96 Grand Prix GTP for a DD, however the turn signals are finicky and the cruise control no longer works. All the vacuum lines seem to be fine and don't appear to have cracks. I suspect the culprit to be the multi function switch (MFS). I used to have an Intrepid and also own a Mustang, and the column separated in half making it very easy to change the MFS. I noticed that the column in the Grand Prix does not separate in half, and was wondering if anyone could provide some insight on how to remove it so I can gain access to the MFS and replace if necessary.
    Thanks
  2. #2 Re: Multi Function Switch
    Brooklyn Center, MN
    I ended up finding a great online resource. Hopefully if others have the same problem, this will help.
    How to replace a Turn Signal Switch on a 94-01 Gen 1 W-Body
    1998 Mustang GT
    PI intake & cams, eibach springs, MM suspension, FRPP 3.73 gears, UDP's, aluminum d/s, magnaflow exhaust
  3. #3 Re: Multi Function Switch
    I know multi function switched arent cheap but i used to work at oreilly auto parts and im sure you can get one through dorneman or BWD. not very hard to do.
  1. Wiper Pulse board or Multi function control
    By JGN in forum General Tech Discussion
    Last Post: 06-09-2010, 02:55 PM
  2. Vindication: We aren't multi-taskers after all
    By SyntheticShield in forum The Rant Forum
    Last Post: 11-01-2008, 08:54 AM
  3. I Need Multi-Conductor Cable
    By SyntheticShield in forum General Tech Discussion
    Last Post: 02-05-2008, 11:15 PM
  4. Broken function
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:14 AM
  5. The Search Function Works!!! OMG!
    By Lawngoose in forum Off Topic Discussion
    Last Post: 12-27-2007, 11:07 PM
