Thread: ball joint maybe?
Results 1 to 20 of 21
  1. #1 Re: ball joint maybe?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    oh, i did not know that. i will inspect today.....
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: ball joint maybe?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    A lot of people have this issue and I've had it as well. One area a lot of people overlook is the subframe bushings. More specifically is the subframe rubber/metal insulators (located between the cradle and the chassis). When ever I backed out of my driveway with the wheel turned you'd feel a clunk.
    This was fixed by replacing the rubber/metal insulators. The old insulator rubber delaminated from the metal part and allowed slop which caused the popping/clunking sound.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  1. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  2. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
  3. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
  4. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
  5. Ball Joint Boot
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 11:17 PM
