Thread: ball joint maybe?
Results 1 to 20 of 21
  1. #1 Re: ball joint maybe?
    From your description I was thinking of what moves when you turn. Strut bearings, the springs get pressures on them, ball joint, strut tower bar has pressure, endlinks flex, sway bars flex and cv's turn
    At first I was thinking spring movement and strut bearings. But....this is a W body and therefore the sway bar coudl be breaking/broken as nearly all of them seem to do.
  2. #2 Re: ball joint maybe?
    GT Level Member tylerbinski's Avatar
    Canada
    jack the front wheels off the ground
    grab wheel at 12'oclock and 6 o'clock position
    try and tilt the tire toward and away .. if there is play.. replace ball joints and go from there.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  2. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
  3. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
  4. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
  5. Ball Joint Boot
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 11:17 PM
