Thread: My 99' GP Needs some help :/
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 My 99' GP Needs some help :/
    Beaumont, TX
    Hey guys... new to the forum..
    Well as I stated, I've been having some problems with my Grand Prix and I can't seem to pin point what the problem is... I have however narrowed it down.
    So one day my car just doesn't turn on. I turn the key and it seems like it's about to start but as the rpm's go down the car dies. My dad claims it could be the fuel pump but I've seen some posts that have said that if you can hear the fuel pump.. it should be good.
    I took it to autozone to get the computer checked and pretty much it said it was backfiring that it could be low or high fuel pressure... ignition system fault... a vacuum leak.. or injector fault.
    Now I know I should be checking all of this.. but I'm trying to hopefully cancel out the more expensive faults first. Which in this case would be the fuel pump or the Fuel Pressure Regulator.
    I checked the fuel pressure regulator and the vacuum line wasn't leaking gas...
    What could it be?
    Oh btw.. if I let the car sit a while.. (couple of hours) it will eventually start and keep running for about 5 minutes before it dies again.
    My uncle suggests it could be the fuel pump.. and that it may be overheating.
  2. #2 Re: My 99' GP Needs some help :/
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    hmm.. probably fuel pump
  3. #3 Re: My 99' GP Needs some help :/
    Beaumont, TX
    So I bought a fuel pump..... Put it on there... Still same problem.... Now I need to catch a ride to work tomorrow. Help is appreciated!
  4. #4 Re: My 99' GP Needs some help :/
    Wausau, WI
    crank position sensor? Just an idea........
  5. #5 Re: My 99' GP Needs some help :/
    '99 Grand Prix GTP?
    If so...
  6. #6 Re: My 99' GP Needs some help :/
    Medford, NY
    '99 Grand Prix GTP?
    If so...
    nice
  7. #7 Re: My 99' GP Needs some help :/
    Beaumont, TX
    '99 Grand Prix GTP?
    If so...
    Nah... sorry forgot to specify.. it's the GT
  8. #8 Re: My 99' GP Needs some help :/
    Beaumont, TX
    Quote Originally Posted by Liquifire View Post
    Thanks
    I'll have a look at that...
    I've checked just about everything.. I changed my spark plugs for the second time in 3 months.. it worked for a bit but it did it again.
    The computer stated vacuum leak as a possible cause... so I'm going to check the PCV valve.
    :EDIT: Also the reason I changed the Spark plugs was because they seemed carbonized.
  9. #9 Re: My 99' GP Needs some help :/
    Wausau, WI
    if you are looking for the vacuum leak, take a can of carb cleaner and start spraying anywhere that there should be vacuum........hoses, connections, etc. The RPM's will pick up if you spray in the area of a leak.
  10. #10 Re: My 99' GP Needs some help :/
    Beaumont, TX
    I'm going to check this tomorrow asap..
    Do you know if it's normal for smoke to come out behind the engine?
    It seems to do that a lot as I try to start it.
    For a second I assumed it could've been the catalyctic converter... but I removed it and tried to start it and got the same result.
  11. #11 Re: My 99' GP Needs some help :/
    Wausau, WI
    It is normal to get a little smoke(from condensation buildup in the exhaust) but not a lot every time you start it out of the exhaust, but what do you mean smoke from behind the engine? If it is coming out of the engine compartment the answer is no.(If you do it could be as simple as an oil leak) What color is the smoke? How long does it last? Does your coolant and oil look normal and are they at the proper levels?
  12. #12 Re: My 99' GP Needs some help :/
    Beaumont, TX
    I guess by saying behind the engine I mean by the exhaust.. It is not much.. but it's black... it could be an oil leak or just the exhaust? It usually just lasts like 5 seconds max and just happens as I start it. And yes both the coolant and oil look normal and at proper levels.
  13. #13 Re: My 99' GP Needs some help :/
    Beaumont, TX
    On the crankshaft position sensor do you loosen the bolt clockwise or counter-clockwise?
  14. #14 Re: My 99' GP Needs some help :/
    Beaumont, TX
    not the crankshaft position sensor either.... could it possibly be the map sensor? It keeps dying when it gets below 1000 rpm It starts for about 5-10 minutes.. and then it dies. After it dies... it won't start again.... It's almost like something's overheating... something has to be overheating.. Once I let it cool down... for hours.. it'll start again... then die in 5-10 minutes. a cycle... I'm scratching my head. help?
  15. #15 Re: My 99' GP Needs some help :/
    Beaumont, TX
    To summarize everything I've changed on the car to try to fix it...
    and well to show how much I've spent :/...
    Fuel pump
    PVC valve
    Crank Shaft Sensor
    changed all those and it's still messed up
  16. #16 Re: My 99' GP Needs some help :/
    Beaumont, TX
    Wow... anyone?
  17. #17 Re: My 99' GP Needs some help :/
    Wausau, WI
    MAF or IAC valve? I dont know.......just guesses at this point. It could be lots of things.....do we know if this is either fuel, air, or spark related for sure?? do you have access to a scanner so that we can see what happens in real time? This would be a huge help.......do you know what the fuel pressures are for sure?
  18. #18 Re: My 99' GP Needs some help :/
    Beaumont, TX
    Hmm... I thinking about my alarm...
    could that be it?
    I heard it stops the car... umm at times it just goes off by itself.
  19. #19 Re: My 99' GP Needs some help :/
    Wausau, WI
    disconnect it and see.........I have never heard of this type of symptoms coming from an alarm though......
  20. #20 Re: My 99' GP Needs some help :/
    MA
    Did you check your battery connection? I had a problem where my keys got stuck in the car sometimes, and the alarm went off randomly. After trying everything I eventually realized the negative connection to my battery was loose.
