Thread: My 99' GP Needs some help :/
Results 1 to 20 of 57
  1. #1 Re: My 99' GP Needs some help :/
    Wausau, WI
    It is normal to get a little smoke(from condensation buildup in the exhaust) but not a lot every time you start it out of the exhaust, but what do you mean smoke from behind the engine? If it is coming out of the engine compartment the answer is no.(If you do it could be as simple as an oil leak) What color is the smoke? How long does it last? Does your coolant and oil look normal and are they at the proper levels?
  2. #2 Re: My 99' GP Needs some help :/
    Beaumont, TX
    Quote Originally Posted by Liquifire View Post
    I guess by saying behind the engine I mean by the exhaust.. It is not much.. but it's black... it could be an oil leak or just the exhaust? It usually just lasts like 5 seconds max and just happens as I start it. And yes both the coolant and oil look normal and at proper levels.
