Thread: Cat Converter
Results 1 to 20 of 38
  1. #1 Re: Cat Converter
    Guam
    A weak or slowly clogging cat will cause the O2 to read funny, thus trip the check engine light. Replacing the cat, or opening up the cat, fixes the O2 reading to be normal again. If left to continue, the O2 will eventually go bad as well. The two go hand and hand.
  2. #2 Re: Cat Converter
    Wausau, WI
    Quote Originally Posted by toolguy View Post
    The can be hand in hand but dont have to be as well. You can just have your 02 sensor go bad, and the cat would be fine. Just get the downpipe through zzp....my bolt in literally bolted right in, excellent fit and no issues whatsoever. I could not be happier with the DP itself. Get new gaskets if you go this route, it will make things easier to seal up on the install if you are going to do this yourself.
  3. #3 Re: Cat Converter
    SE Level Member VGPGT's Avatar
    Hammond, WI
    I just got my 3" downpipe with cat from ZZ Performance. I know it was been too long, but my pocket book was slowing up the purchase... Plan to install it this Saturday. Anything special I need to know?
    '97 GT Coupe '99 GT Coupe '06 GT Sedan
    Past cars include '76 Grand Prix, 1993 SE Sedan, '97 GT Sedan 01 SE Sedan '03 GT Sedan Limited Edition
  1. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  2. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  3. 04 cat converter.
    By rcweldon988 in forum 04+ Specifics
    Last Post: 02-18-2009, 08:21 AM
  4. bad converter again
    By shawn in forum General Tech Discussion
    Last Post: 02-16-2009, 03:11 PM
  5. ZZP Converter doesn't line up ?
    By Meemperor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2008, 10:13 PM
