Thread: sc oil
Results 1 to 9 of 9
  1. #1 sc oil
    Joliet, IL
    hey guys i had to drill out a stripped snout fill plug and i tapped it hold a new bolt....i thought i had got all the metal shavings out but i guess there was some very fine powder dust because my sc oil looks like silver sharpie ink....anything i can use to flush it out a bunch of times so i dont have to buy sc oil so many times?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: sc oil
    Banned - Busted For Scamming
    Feb 2009
    Buy a snout from me and dont strip out the plug this time.
  3. #3 Re: sc oil
    Joliet, IL
    you think that metal fukked up my rotor pack too?
    00 Silvermist GTP
  4. #4 Re: sc oil
    Feb 2009
    Probably not, but if you want with your blower i can send a recoated rotor pack for a small charge.
  5. #5 Re: sc oil
    Joliet, IL
    that ok i think mine is ok ill prob just send you my snout and hopefully you have a mps zzp hub to press onto it
    00 Silvermist GTP
  6. #6 Re: sc oil
    Just drain the oil and save yourself the money and put new oil back in it. YOu have to do the same thing when you get a polished blower...the SC oil just picks up all the fine particles...it isn't going to harm anything. Just change it.
  7. #7 Re: sc oil
    I'd suggest pulling the snout and rinsing with brake cleaner. Put it back together and refill.
    Brake cleaner shouldn't harm anything and will remove residue etc. Refilling with oil will relube the bearings.
  8. #8 Re: sc oil
    Charles City, IA
    ^ thats what I would do.
    SMGPFC Two Nipple General
  9. #9 Re: sc oil
    Moore, Oklahoma
    yep, if you got shavings in the snout i'd pull off the snout (which is easy enough), clean it real good on both sides, reinstall it and put in fresh oil. Simple as that...
    Shawn W. Larsen
oil
