Thread: Wide Band Question
Results 1 to 14 of 14
  1. #1 Re: Wide Band Question
    May 2008
    staten island,NY
    digital is more accurate, why take a chance on reading an analog? wideband is one of the best tools for tuning as well as keeping tabs on the engine. dont risk popping a piston trying to read an analog gauge
  2. #2 Re: Wide Band Question
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by QwikGT View Post
    Nope. They are just as accurate (.1 AFR). If you are trying to keep an eye on a tenth of an AFR while trying to drive you are asking for an accident. Use the analog output to get and record the exact readings and they will be the same whether you use analog or digital. Just looking at a gauge doesn't do much for you anyway. When you log you can know the AFR in context with the vacuum/boost, MAF, LTFT, etc. which is when it actually becomes helpful for tuning. You are not going to be able to do that when looking at the gauge while you are driving. When you drive all you want to do is know if it is off from what it normally is so that you can spot a potential problem like if it is lean at WOT then you can get your foot out of it before damaging the engine. Then analog can do that just fine and it is easier to read out of your peripheral vision.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  3. #3 Re: Wide Band Question
    Barksdale AFB, LA
    Quote Originally Posted by Going Too Phast View Post
    2009 Subaru Impreza WRX STI
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. Difference between GTP and GXT... is there one?
    By kjclawson in forum General Tech Discussion
    Last Post: 08-09-2009, 12:34 PM
  3. Spotting the difference
    By BankRupt in forum Off Topic Discussion
    Last Post: 08-01-2008, 08:19 AM
  4. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
  5. difference between gt and gtp trans
    By robahr24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-13-2008, 07:30 PM
