Thread: Disabling the Door Chime?
Results 1 to 19 of 19
  1. #1 Re: Disabling the Door Chime?
    Banned
    New Port Richey Florida
    Could someone post a pic of the 97-03 chimie module for me please if they have it so I can see what it looks like. Cause I was thinking about putting the 97-03 chime module in my car if it can be done
  2. #2 Re: Disabling the Door Chime?
    GT Level Member BackInBlack's Avatar
    Vermont
    The door chine is handled by the BCM. I can certainly tell you which wire to disconnect. BUT, I think I need the big number off the sticker on the side of the BCM... I might not, but just in case...
    The GPs are long gone...
  3. #3 Re: Disabling the Door Chime?
    Wichita, KS
    All BCMs are different, and the wiring changed from year to year, from model to model.
    I too find this annoying, so instead of taking the chance f-ing something up, here is what I do to get by.
    When the doors open, with your finger, or a small screw driver, or even your car key, push in the part that rotates around the striker inside the door its self, that actually holds the door closed. When you do this, the door thinks its closed, and off goes the chime.
    To undo the closed "hook" in the door, BEFORE you forget and shut the door with it closed, with your key, or a screw driver you insert it in the side opening of the door, pull up on the out side or inside door handle as if you were opening the door, and then just pull towards you and it will open back up easy.
    I say you can use your car key, as this moves VERY easily, and there is no strain on the key what so ever. Its always been nice and smooth for me on all the cars I have ever done this to. But you can use a small regular sized screw driver if you want, or even your finger, if you can get it in there. I can, but with my pinkie finger.
    Hope that helps.
    ~F~
  1. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
  2. 1/4 mile times of 4 door gtp's
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2008, 08:41 PM
  3. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
  4. Rear door will not shut *Solved*
    By Fish in forum Visual/Body Modifications
    Last Post: 12-25-2007, 02:53 AM
