I have no idea, as yours is much newer than mine. Is it still under warranty? I would call the stealership and see if they can check it out for free.
did you have the car running? im not sure how its done for a car with a button but try with the key on the on position. not running the motor then trying it.
all other vehicles all you have to do is turn the key to on position press the gas pedal 3 times all the way down and let it come back all the way up withinn 5 seconds. if that doesnt work i use the throttle body linkage because some vehicles have an error between the pedal and throttle body.
then again you might have the etc (electronic throttle control) where you could only use the pedal.
Hope that helps
Chris
