Thread: Miss Lisa,s GTP climate control problem
Results 1 to 3 of 3
  1. #1 Miss Lisa,s GTP climate control problem
    Georgia
    The exterior temp display for the climate control on her 99 GTP reads about 30 degrees to low for about the first 10 miles of driving each time it is driven. This causes the ac to not work untill it corrects itself. Where is the sensor for the climste control located?
  2. #2 Re: Miss Lisa,s GTP climate control problem
    Wausau, WI
    I thought there was only one external temp sensor and thought that it was located on the lower support bar for the radiator near the bottom.
  3. #3 Re: Miss Lisa,s GTP climate control problem
    Banned - Busted For Scamming
    Feb 2009
    The very front of the car.
  1. Climate control problem
    By LSXHP in forum General Tech Discussion
    Last Post: 07-31-2009, 01:01 AM
  2. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  3. climate control
    Last Post: 01-27-2009, 09:10 PM
  4. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
