Thread: Oil change light indicator
Results 1 to 13 of 13
Threaded View
  1. #12 Re: Oil change light indicator
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by skidoojames151 View Post
    personally i would run conventional oil and change ever 3000...think about it, running synthetic for 7000 only means the oil is more contaminated and the filter is more clogged and contaminated as welll...plus its still cheaper to buy conventional every 3000 than synthetic every 7000
    false.
    that may be true the very first time, as the synthetic does its "cleaning" but after running it a time or 2, there will be absolutetly nothing there capable of clogging the filter. this is why when you run synthetic or a synthetic blend for the first time, its recommended to change it sooner then normal
    synthetic oil doesnt sludge up like conventional,
    in fact it does the opposite, cleans! it also conditions seals to prevent cracking/deterioration, it has better flow properties, and it protects better. when you buy synthetic, youre getting ALOT more then just an extended oil change interval
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. change oil light.
    By Ironwarrior in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-05-2009, 03:44 AM
  2. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
  3. Change oil soon light!
    By MARKS99 in forum General Tech Discussion
    Last Post: 07-20-2009, 07:44 PM
  4. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  5. change oil soon light
    By adamlesandrini in forum General Tech Discussion
    Last Post: 03-25-2009, 04:42 PM
