Thread: gto swap
Results 1 to 20 of 23
  1. #1 Re: gto swap
    Barksdale AFB, LA
    It is nearly impossible. It can be done, but there's so much modifying to everything that has to happen first that it's out of reach for most people who don't work in or own their own machine shop.
    2009 Subaru Impreza WRX STI
  2. #2 Re: gto swap
    Jan 1970
    Maquoketa, Iowa
    basically take a sawzall to the underside of the grand prix, cut everything out until you can literally walk, still touching the ground, from the engine bay back to the trunk of your car. Then fab up a new frame and you are now ready to start fabbing up everything else. It's similar to a top swap.
  3. #3 Re: gto swap
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    lol
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: gto swap
    GT Level Member BoostedComp's Avatar
    Youngstown
    haha yeah just a bolt or two different
  5. #5 Re: gto swap
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    hahaha yeah its about as easy as spending 20 grand on a gto...
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  1. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-02-2009, 05:32 AM
  2. L67 Top Swap on 05 L26
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2009, 10:53 AM
  3. What wil i need to do a top swap
    By gp3800t in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 08:34 PM
  4. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
