Well, My HUD was intermitantly coming on, fading away, then disapearing, only to reappear when i turned right, or left, or hit a bump. It seemed to be extremely bright when i turned on the car.
So i figured "hey it COULD be the sun sensor". WRONG! After a FULL dis-assembly, and cleaning of the unit, The only noticible damage was on the actual LCD itself, Where the #1 pin of the ribbon cable was going in the unit, im assuming is power, there was a small "size of a rice pellow" burn mark on the LCD directly where the cable was entering the sealed LCD. I figure this could be the issue.
I check all of the circuit boards, and see no burn marks anywhere. I check the solder of the photo sensor, and it is practically brand new, FULL solder the entire way around the pins, So i say well, i guess that burn in the LCD is a short, that is causing it to heat up, gain resistance, and fade away.
So i re-assemble everything, install all the little tiny black plastic clips, and re-insert the 20 pin ribbon cable, clean the mirror, clean the plastic cover, screw it all back together, then FINALLY toss it in the car.
Crank her up, and Suprise, the HUD works perfectly.
I did nothing, literally NOTHING except for clean off a little dust from the mirror/plastic, and replug everything back in.
Now it stays nice and bright, day or night, and never fades.
Total cost for this repair - 1 hour of labor, whilst slacking ALOT.
I was so worried i would have to end up purchasing another HUD unit.
100$ SAVED
