Thread: window wont go down
Results 1 to 3 of 3
  1. #1 window wont go down
    roselle
    i put my driver side window up today and i went in the car later and it wont go down
  2. #2 Re: window wont go down
    SE Level Member singularity's Avatar
    Houston, Tx
    check your voltage at the motor with a volt meter, if you have voltage, time to replace the motor (its just a 2 prong connector)
    If you dont have voltage, the switch may be bad, check continuity on the switch
  3. #3 Re: window wont go down
    Donating Users Liquifire's Avatar
    Wausau, WI
    ^^^^^^what he said
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  1. my key wont
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 11:38 PM
  2. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  3. Replies: 4
    Last Post: 05-23-2009, 12:21 AM
  4. put it back together, now wont run
    By 99gpse in forum General Tech Discussion
    Last Post: 02-20-2009, 07:06 PM
  5. need help GP wont run
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-29-2008, 06:23 AM
