ALSO, my low coolant light keeps coming on when the coolant is full...I'm having some problems with the engine burning up coolant which hopefully will be fixed dureing the swap but still does this mean anything? Is there a bad sensor somewhere?
yes.........there is a low coolant sensor.........if you end up changing it, be prepared to leak some fluid as well.......
