Thread: S/C snout swap??
Results 1 to 13 of 13
  1. #1 S/C snout swap??
    south florida
    Im changing the snout on my sc, what kind of gasket sealer do you prefer to use when you put it back together? Also, while the snout is off Im thinking of having the pulley installed by a friend that has a 60 ton press at his shop, are there any precautions to look out for when doing this, is there any reason I should not have it done with a press or would it be ok as long as you use caution. Thanks
  2. #2 Re: S/C snout swap??
    Charles City, IA
    Don't use a press for the pulley. Just rent the tool and do it right. Do you have any mods to support the pulley? If not don't put it on. You just need some aerobic sealant for the snout.
    SMGPFC Two Nipple General
  3. #3 Re: S/C snout swap??
    Bastard Reptile's Avatar
    Kansas City, MO
    I've seen guys do it with a press at shops, just be very careful with the pulley.
    As for what to use to seal it up, use an anaerobic gasket maker. It's made for the surfaces that are machined like the snout to rotor section is.
  4. #4 Re: S/C snout swap??
    south florida
    Thanks guys, anaerobic gasket sealer was what I was looking for, I have been modding this car for years but have never pulled the snout off. I was told that as long as I put something like a socket behind the shaft to support it, a press would be ok for the pulley, just wanted a few other opinions. Im going up in pulley size and I have enough supporting mods so that should not be an issue.
  5. #5 Re: S/C snout swap??
    GT Level Member skidoojames151's Avatar
    seattle
    you mean going down in pulley size??
  6. #6 Re: S/C snout swap??
    Jersey
    Quote Originally Posted by skidoojames151 View Post
    16' wrx sti- stock
  7. #7 Re: S/C snout swap??
    south florida
    Nah, pretty sure going from a 3.25 to a 3.4 is going up in pulley size.
  8. #8 Re: S/C snout swap??
    Banned - Busted For Scamming
    Feb 2009
    Where are you in florida?
  9. #9 Re: S/C snout swap??
    i dont use anything to seal my blower and ive had it apart multiple times. never leaks.
  10. #10 Re: S/C snout swap??
    south florida
    Im on the east coast in Martin county, Stuart
  11. #11 Re: S/C snout swap??
    Feb 2009
    Ahh, im from orlando, your south of me pretty good.
  12. #12 Re: S/C snout swap??
    south florida
    Im a couple of hours from Orlando. This place is pretty lame for GPs, modded ones anyways. When I hit the track at Moroso in Palm Beach Im usually the only GP running out of a hundred or so cars.
  13. #13 Re: S/C snout swap??
    Feb 2009
    That blows, i usually see a few here and there with visual mods. I saw one a while ago not far from me that had an intercooler, couldnt find out who it was though, was parked in a target parking lot.
  1. snout!!!HELP QUICK!!!
    Last Post: 08-06-2009, 12:39 PM
  2. leaking s/c snout?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 07:47 PM
  3. snout plug
    By ROTTMAN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 06:46 PM
  4. Can i flip my snout around
    By Merlin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 02:31 PM
