Thread: A/C and Daytime running lights
Results 1 to 2 of 2
  1. #1 A/C and Daytime running lights
    N.C.
    I have an intermittant problem with the A/C. When it works, all is well, when it does not work, I will switch the fan to 1-5 and nothing happens with the fan or the A/C and the daytime running lights shut off.
    The radio display is also glitchy.
    Some online sites suggest the ignition switch is the culprit.
    The basics: 1998 Grand Prix SE
  2. #2 Re: A/C and Daytime running lights
    Wausau, WI
    my radio display sometimes appears to display a foreign language on it for no rhyme or reason and it just fixes itself.......I do not have any of your other issues however........not sure if they are related or not. Bad relay? anyway lets start with the basics.........what year make and model are you?
  1. Daytime running light (DRL) modification help
    By Vinton GP in forum General Tech Discussion
    Last Post: 09-28-2009, 08:09 PM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  4. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
