Thread: got in a wreck...need help...
Results 1 to 14 of 14
jayetune08 got in a wreck...need help... 08-12-2009, 10:26 PM
CTKGP09 Re: got in a wreck...need... 08-12-2009, 10:34 PM
jayetune08 Re: got in a wreck...need... 08-12-2009, 10:39 PM
CTKGP09 Re: got in a wreck...need... 08-12-2009, 10:43 PM
jayetune08 Re: got in a wreck...need... 08-12-2009, 10:51 PM
jayetune08 Re: got in a wreck...need... 08-13-2009, 08:29 AM
Liquifire Re: got in a wreck...need... 08-13-2009, 08:33 AM
jayetune08 Re: got in a wreck...need... 08-13-2009, 11:48 AM
jayetune08 Re: got in a wreck...need... 08-13-2009, 11:53 AM
jayetune08 Re: got in a wreck...need... 08-13-2009, 03:32 PM
Liquifire Re: got in a wreck...need... 08-13-2009, 04:38 PM
jayetune08 Re: got in a wreck...need... 08-13-2009, 04:50 PM
Liquifire Re: got in a wreck...need... 08-13-2009, 05:16 PM
jayetune08 Re: got in a wreck...need... 08-13-2009, 08:26 PM
  1. #1 got in a wreck...need help...
    new orleans
    so i tried to teach ma boo how to drive and she didn't make it 2 blocks...big mistake on my part. she hit a stop sign and messed up the bumper and the passenger side headlight and foglight. later i also found out the windshield washer container and horn were also messed up. both the fog light and the headlight on the passenger side wouldn't come on. while replacing the light i saw that a few wires had been cut in the process...i chrimped them all back together and the light still doesn't work. whatelse could be the problem?
  2. #2 Re: got in a wreck...need help...
    Willoughby, Ohio
    well first off those r some tuff stop signs...second off check the fuses bc there is a possibility the wires shorted out and check the bulbs themselves
  3. #3 Re: got in a wreck...need help...
    new orleans
    i replaced the lights with projectors so i know its not the lights. are the fuses for the lights in the fuse pannel on the passenger side or under the hood?
  4. #4 Re: got in a wreck...need help...
    Willoughby, Ohio
    under the hood if i can recall correctly
  5. #5 Re: got in a wreck...need help...
    new orleans
    thanks..i'll try that tomorrow and keep you updated
  6. #6 Re: got in a wreck...need help...
    new orleans
    i checked the fuses...there not blown. anything else anyone can think of?
  7. #7 Re: got in a wreck...need help...
    Wausau, WI
    well........do you have power @ the light locations when you turn them on or not(use a meter or test light) does the other half of the lights come on the other side or do you have no lights?
  8. #8 Re: got in a wreck...need help...
    new orleans
    i driver side works flawlessly. its just the passenger side.
  9. #9 Re: got in a wreck...need help...
    new orleans
    this is where i am so far... i fully intend to crimp the wires but i just twisted them together to see if i could get any results...and i didn't. i don't know if i'm getting voltage because i don't have a voltage meter handy..i'll pick one up later today.
    also..where does this go? could it be my problem?
  10. #10 Re: got in a wreck...need help...
    new orleans
    bump.....nobody?
  11. #11 Re: got in a wreck...need help...
    Wausau, WI
    is that the plug that goes into your windshield washer tank(the pic with the battery and plug in it)?
  12. #12 Re: got in a wreck...need help...
    new orleans
    i don't have a clue what it is. thats why i asked...is that where it goes? that wouldn't have anything to do with my lighting problem would it?
  13. #13 Re: got in a wreck...need help...
    Wausau, WI
    I dont know where that plug goes for sure. I actually have a spare plug near that location that looks similar, but have no idea what it is for. It should have nothing to do with your lights if that is what it is for.......
  14. #14 Re: got in a wreck...need help...
    new orleans
    no one knows? i guess i'll just have to take it to the shop
  1. Another car wreck
    By 2Fast4U in forum Off Topic Discussion
    Last Post: 06-20-2008, 12:07 AM
  2. car wreck dam semi
    By Rocket468 in forum Off Topic Discussion
    Last Post: 05-18-2008, 08:28 PM
  3. my rant--wreck
    By Dealer in forum The Rant Forum
    Last Post: 02-04-2008, 07:31 PM
  4. Bad Wreck Photos
    By GTPluv in forum Off Topic Discussion
    Last Post: 12-17-2007, 12:12 PM
