Thread: Swap time soon...do I have everything?
Results 1 to 13 of 13
  1. #1 Swap time soon...do I have everything?
    Oct 2008
    Northern Illinois
    Let me know if I'm missing anything, also I won't be buying an aeroforce just yet I know someone with a tuner that we can use to scan for KR. Were throwing a decent tune on there, and I'm eaither getting a DP/PL or pacesetters, haven't decided yet.
    L67 PARTS:
    • Gen III Supercharger
    • TB
    • LIM
    • Balancer
    • Injectors
    • Heads
    • Fuel Rail
    • Vac Lines
    • Map Sensor
    • Idler Pulleys
    NEW PARTS:
    • Head Gaskets
    • Head Bolts
    • Intake Manifold Gaskets
    • SC Gaskets
    • Rocker Bolts
    • Valve Cover Gaskets
    • Coolant Elbows
    • 12 Injector O-Rings
    • 2 Sets Of Oil Changes
    • Dexcool Coolant
    • AL 104s
    • 180 T-Stat
    • Fuel Filter
  2. #2 Re: Swap time soon...do I have everything?
    looks to be everything. port the blower, lim, and TB while they are off.
  3. #3 Re: Swap time soon...do I have everything?
    Oct 2008
    Northern Illinois
    If I knew how to do it I would, I might have mini do it but idk if I should be spending the money.
  4. #4 Re: Swap time soon...do I have everything?
    its better to get it done now when you dont NEED the parts than when you need them to drive your car. and realistically its not that hard so long as you take your time and dont gouge anything really bad.
  5. #5 Re: Swap time soon...do I have everything?
    Wausau, WI
    please switch from the dexcool.............I would
  6. #6 Re: Swap time soon...do I have everything?
    Banned - Busted For Scamming
    Feb 2009
    How far away is your top swap? Might cut you a deal if i have the time.
  7. #7 Re: Swap time soon...do I have everything?
    Quote Originally Posted by Liquifire View Post
    i would use the green stuff or yellow stuff. anything but the dexcool. i run green in my car.
  8. #8 Re: Swap time soon...do I have everything?
    Oct 2008
    Northern Illinois
    A few weeks, yeah I'm VERY short on cash right now so if you could cut me a good deal on the blower/tb porting that'd be awesome.
  9. #9 Re: Swap time soon...do I have everything?
    Grand Island, Nebraska
    how much would you estimate it cost for you to get all the parts?
  10. #10 Re: Swap time soon...do I have everything?
    Oct 2008
    Northern Illinois
    Not much because I found a really good deal on the L76 parts, I got all of those things listed under L67 parts for $300, then somewhere around $250 for all those gaskets and and other misc. things like oil, coolant, sparks, wires, thermo. Now I just need a downpipe, if he can get them off his car in time for the swap I'm buying a DP/PL off a member on here for 180 which is an awesome deal because ZZP charges 190 for just the catted dp.
    So recap $550ish for everything, plus the DP/PL.
  11. #11 Re: Swap time soon...do I have everything?
    Only things I see missing are non-parts.
    A sealantwith PTFE for the LIM, timing cover and SC idler bolts. (They can all seep w/o the sealant)
    Permatex Ultra Copper (tube) RTV for the corners of the LIM gaskets where the head/block meet.
    I'd probably go AN fuel lines to keep from mangling the stock plastic ones to meet the different rail.
  12. #12 Re: Swap time soon...do I have everything?
    they actually bend pretty nice to meet up to where they are supposed to go if you twist the head on them a little bit, but you have to make sure that you dont let them sit by the EGR or youll burn right through it like i did. now i dont have an EGR.
  13. #13 Re: Swap time soon...do I have everything?
    Jersey
    BAM!
    16' wrx sti- stock
  1. First time here
    By manticore in forum Introductions/Noob Questions
    Last Post: 06-17-2009, 05:15 PM
  2. 0-60 time
    By Davisgtp in forum Off Topic Discussion
    Last Post: 02-19-2009, 11:08 AM
  3. First Time
    By purplehaze97 in forum Introductions/Noob Questions
    Last Post: 02-16-2009, 04:49 AM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. Had a little time!
    By ldyzluvdis06 in forum Visual/Body Modifications
    Last Post: 05-30-2008, 09:48 AM
