Thread: Final drive ratio question
Results 1 to 18 of 18
  1. #1 Re: Final drive ratio question
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    II:
    As my memory breaks off the crust and cobb webs, I think you have it correct. I have seen 04 and newer GPs that are GTs with the "2" VIN code which was the N/A 3.8.
    After reading more last night, I am thinking that the gearset itself is a 3.29 ratio, and that the 2.93 is the effective ratio when in OD.
    Don
  2. #2 Re: Final drive ratio question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by 07CrimsonGT View Post
    II:
    Very close. The differential (final drive) on all of the GPs is 3.29:1. The difference in on the input side, where the drive chain is overdriven with the supercharged engine; the NA trans use sprockets with 35 teeth on both, where the supercharged trans uses 33 on one and 37 on the other, giving it an effective 2.93 overall ratio. The individual gear ratios work from that, so the effective ratio in OD would be 2.93 * .71 = 2.08
    2001 Buick Regal LS - Almost Stock
  1. air fuel ratio ?
    By eddie97gt in forum General Tech Discussion
    Last Post: 02-17-2009, 05:46 PM
  2. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
  3. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
  4. Changing internal gearing? (not final drive)
    By Ron Vogel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 02:27 AM
