Thread: Push button for park-lock solenoid in column??
Results 1 to 7 of 7
  1. #1 Re: Push button for park-lock solenoid in column??
    Ohio
    I havent a clue if theres a special tool but what i did was I just took a zipstrip and put it around the solenoid holding it in the pressed position. problem solved!
    00 GTP demodded and forsale
  2. #2 Re: Push button for park-lock solenoid in column??
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    Quote Originally Posted by speedemongtp View Post
    hey man i got a rubber band doing mine! haha. Is this a really dumb idea for us tho because it can be pushed into reverse while in drive going forward and could possibly get bumped. Also you can shift gears with no keys when the car is off.
    Kinda scary not having this saftey feature of the lock.
    have you had any problems?
  1. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  2. Short in Tilt Column? Occasional No Start
    By randye in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2010, 02:14 PM
  3. Possible short in tilt column = no start?
    By randye in forum General Tech Discussion
    Last Post: 08-12-2009, 03:13 PM
  4. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
