Thread: Pulling to the Ditch and Vibrating
Results 1 to 6 of 6
  1. #1 Pulling to the Ditch and Vibrating
    SE Level Member Hawkins97's Avatar
    Wabash, IN
    I just bought a 2002 Grand Prix SE about 2 or 3 months ago. The car has 160,000 mi on it but the interior is spotless and the engine is mechically sound. No leaks or anything, plus I only gave 3K for it. But ever since I've had the car even when I've test drove it both times, the car will vibrate under strain. The more gas you give it the more it vibrates. Also I've had it aligned and when your going down the road giving it no gas at all it will go perfectly straight, but as soon as you touch the gas, it wants to pull to the ditch. I've took it several places and some said it was the wheel bearing so I replaced it. Other said it was the struts. I'm going to replace those as well. But does anyone have any advice or maybe some good words for me problem? If you do please leave me something. Thanks, Chris.
  2. #2 Re: Pulling to the Ditch and Vibrating
  3. #3 Re: Pulling to the Ditch and Vibrating
    GT Level Member skidoojames151's Avatar
    seattle
    how much is a touch to the gas...like nailing it? cuz that could be the torque steer
  4. #4 Re: Pulling to the Ditch and Vibrating
    seattle
    but being a SE i doubt you have that much torque steer going on
  5. #5 Re: Pulling to the Ditch and Vibrating
    Wabash, IN
    Well.. it just depends on how much gas you give it depends on how much it pulls.. If you nail it, it doesn't hesitate at all, it just goes straight over.. But giving it a little bit of gas will gradually make it float to the right.
  6. #6 Re: Pulling to the Ditch and Vibrating
    seattle
    roads do naturally slope towards the ditch for draining purposes...unless its really bad...then i would put it on a lift and check everything out
  1. Pulling a Pulley
    By jagamite in forum General Tech Discussion
    Last Post: 11-14-2008, 08:12 AM
  2. Last ditch effort to recoup my losses...
    By BackInBlack in forum Off Topic Discussion
    Last Post: 07-23-2008, 03:29 PM
  3. Car Vibrating badly
    By bcrosby51 in forum General Tech Discussion
    Last Post: 07-23-2008, 07:52 AM
  4. FWI without pulling the bumper.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 05-14-2008, 08:35 AM
