Thread: Bad Trunk rattle
Results 1 to 12 of 12
jjwitty Bad Trunk rattle 07-25-2009, 11:30 AM
Melancholy43920 Re: Bad Trunk rattle 07-29-2009, 05:17 PM
gtpinsc Re: Bad Trunk rattle 07-29-2009, 05:26 PM
Ice Blue La Crosse Re: Bad Trunk rattle 07-29-2009, 06:54 PM
MysticStyl3z Re: Bad Trunk rattle 07-29-2009, 09:55 PM
LOUDANDPROUDGTP Re: Bad Trunk rattle 07-29-2009, 10:08 PM
SlowM90 Re: Bad Trunk rattle 07-30-2009, 12:17 AM
LOUDANDPROUDGTP Re: Bad Trunk rattle 07-30-2009, 10:52 AM
Liquifire Re: Bad Trunk rattle 07-31-2009, 01:08 AM
blueguy Re: Bad Trunk rattle 07-31-2009, 10:58 AM
jjwitty Re: Bad Trunk rattle 08-01-2009, 09:29 PM
CMURDAx Re: Bad Trunk rattle 08-05-2009, 01:21 AM
  1. #1 Bad Trunk rattle
    Indy
    Got my 12" JLs(2) w/1000watt Power Acoustic amp installed and now there's a horrible rattle in the trunk area. Anyone have this problem and solve it?
  2. #2 Re: Bad Trunk rattle
    SE Level Member Melancholy43920's Avatar
    East Liverpool, OH
    Well that's what 1000 watts does to the trunk of any car! You can make sure all the bolts are tight, make sure the spoiler is still secure, check the spare tire compartment, etc. Or you can Dynamat it.
  3. #3 Re: Bad Trunk rattle
    Jul 2008
    sumter,south carolina
    carpet padding behind the license will help u a good bit.
    02 GTP with mods 05 GP for DD
  4. #4 Re: Bad Trunk rattle
    memphis
    Dynamat it
  5. #5 Re: Bad Trunk rattle
    Dec 2008
    Naperville, IL
    yeah when you are running a decent amount of power to a trunk... you ARE going to have rattle most of the time. if i were you, id buy a roll of sound deadening material (dynamat, RAAM mat, second skin). do your whole trunk and a few layers on the trunk lid. that will help and also add some weight to it.
    i wouldn't worry about it TOO much. you shouldn't be concerned about what it sounds like on the outside. the inside is what really counts.
  6. #6 Re: Bad Trunk rattle
    Houston, TX for now
    I had 6000 watts, 2000 RMS in the trunk with almost zero rattle. But then again I am very OCD sometimes. I stripped everything out of the whole car short of the dash. then I filled all of the cavities in, under, and around the car with expansion foam. There are a lot of them around the trunk. Then I removed the rubber flaps out of the vent in the bottom of the trunk, got rid of the spare tire and coated the entire floor from the dash to the trunk with sound deadening spray. I also put sound mat and four bolts in the license plate. Extra sound material over the sheet metal where the tail lights are took care ov the last few rattles. But like I said I'm OCD sometimes.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  7. #7 Re: Bad Trunk rattle
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by LOUDANDPROUDGTP View Post
    my lord..I bet your car is a PIG!!!!! but im sure it sounds good
  8. #8 Re: Bad Trunk rattle
    Houston, TX for now
    Actually not too bad. The last time I weighed it I had a little over half a tank and it came in at 3,842. I have been able to shave some weight here and there.
  9. #9 Re: Bad Trunk rattle
    Wausau, WI
    got greatstuff?
  10. #10 Re: Bad Trunk rattle
    Get rid of subs they are stupid. Bigger the stereo the slower you go. Then you won't have an annoying rattle AND you'll go faster.
  11. #11 Re: Bad Trunk rattle
    Indy
    well i'm not a racecar driver so i doubt a 30 pound box will make much a difference
  12. #12 Re: Bad Trunk rattle
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    i got a 3600watt amp pushin a single 12" kicker l7 and it makes my rear bumper rattle and **** inside my wheel well. but when your inside i can only hear my stick amp rattling against the metal on the top of the trunk =[. but if you turn it up louder you wont be able to hear any rattling =]
  1. 2006 Bad Trunk Rattle
    By jjwitty in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2010, 02:13 AM
  2. Rattle under hood
    By bronzegp in forum General Tech Discussion
    Last Post: 07-17-2009, 08:05 AM
  3. rattle on accelleration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:31 PM
  4. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
  5. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
