Thread: L32 connecting rods, Stupid question
Results 1 to 5 of 5
  1. #1 L32 connecting rods, Stupid question
    Apr 2009
    Lima, Oh
    ok. here's my stupid question. i bought some brand new GM Genuine L32 connecting rods for my GTP. why are the cap and rod both one piece. theres a notch cut in it but theres no seam. what am i supposed to do with these rods? do i have to cut or break them to install them?
    2002 Black GTP, 3.2 pulley, CAI, Pacesetter Headers, 180 thermostat, xp cam, L32 rods, zzp pcm, N* TB, FWI
  2. #2 Re: L32 connecting rods, Stupid question
    Take the bolts out?
  3. #3 Re: L32 connecting rods, Stupid question
    Donating Users mystic231's Avatar
    Michigan
    DO NOT CUT THEM. Crack them. The rods came to the assembly line just like you received them and were "cracked" as the pistons were stuffed into the bores, being very careful to keep the correct cap with the correct rod as they were truely a matched set. "Cracking" the caps assures perfect alignment and provides a stronger connection.
    Some other thoughts on the subject:
    Powdered Metal rods are made up of a composite of alloys that allow rod caps to be "cracked" at the parting line rather than split with a straight cut.
    It comes out of the casting process the final size and is broken at a scored line that is part of the design.
    The resulting fracture is like a piece of broken china. It has a very distinctive surface that custom fits together. The fracture has more surface area because you have peaks and valleys, and the alignment is more accurate since the cap only fits together one way.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: L32 connecting rods, Stupid question
    TDCRacing
    Guest
    Good info there. Thanks for that.
  5. #5 Re: L32 connecting rods, Stupid question
    Apr 2009
    Lima, Oh
    i tried to post.. i dunno if it went thru.. sorry if this is a repeat.. but how do i crack them? do i just remove the bolts or what?
  1. Tell me the truth about L32 Connecting Rods
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2011, 01:54 AM
  2. Stupid Question
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2009, 01:23 AM
  3. Stupid Question time, What is this?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 07:22 PM
