Thread: Resonator size
Results 1 to 9 of 9
  1. #1 Resonator size
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    I'm lookin for some clarification, fellas. I've got a complete 3" exhaust on my GTP, with dual magnaflows... and it's got a bit of a drone... i'm wanting to put a resonator in to help with that... does anyone know what the largest diameter body size is that will fit in the tunnel? is it 5 or would a 6" fit?
  2. #2 Re: Resonator size
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Not sure, but this is what I would use.
    Summit SUM-630820 - Summit Glasspack Mufflers - summitracing.com
    I used one on my exhaust for the same reason and I was VERY happy with the results.
  3. #3 Re: Resonator size
    SE Level Member Coogles's Avatar
    The Stainless Works resonator that I have is 6" in diameter and, honestly, it's a bit large for our exhaust tunnel. It hangs down a small amount past the undercarriage. That, couple with the fact that I'm lowered on Gen 2 SSC's means that it doesn't like the large speed "humps" very much. While it hasn't been damaged and I've never had any problems, it's size is a bit of a concern. It'd probably be best to stick with a 5" round or smaller, but 6" does fit.
    Forest Green 1998 GTP Sedan - SOLD
    VS, 3.2, TOG, GMPP Suspension, 3EP Tune
    13.179 @ 106.57 w/2.005 60'
  4. #4 Re: Resonator size
    SW Chicago Suburbs
    Quote Originally Posted by Coogles View Post
    i was kinda thinkin that it might be too big.
    i'm lookin at this style now... flow pro from zzperformance
    Resonator size Attached Images
  5. #5 Re: Resonator size
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I know it's hard to tell from a picture but sisnce that resonator isn't straight through, there may be a potential for KR. The one on my catback, removed by Trannyman, was straight through but had raised ribs and gave me 6* of KR no matter the pulley installed.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Resonator size
    SW Chicago Suburbs
    Quote Originally Posted by IndeedSS View Post
    hadnt thought about KR... its not completely straight through, no... but it keeps the flow @ 3" so no reduction there...
  7. #7 Re: Resonator size
    Las Cruces, NM
    The Summit one is straight through.
  8. #8 Re: Resonator size
    SW Chicago Suburbs
    Quote Originally Posted by VinnieGTP View Post
    which is why im afraid it wont do much to cut the drone of my magnaflows
  9. #9 Re: Resonator size
    Las Cruces, NM
    I have the SLP loudmouth and it worked great.
  1. what size rim
    By blazedgp in forum Tires & Wheels
    Last Post: 02-20-2008, 01:49 PM
  2. resonator?
    By MikeGTP88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2008, 04:25 PM
  3. Resonator
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2008, 09:38 AM
  4. Sig size question
    By fatride99 in forum Site/Club News
    Last Post: 01-27-2008, 09:17 PM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
