Thread: rocker moulding removal
Results 1 to 3 of 3
  1. #1 rocker moulding removal
    pa
    i want to remove the driver's side rocker panel moulding on a 2000 grand prix gt coupe. besides the 4 screws, what has to be done to remove the moulding? thank you.
  2. #2 Re: rocker moulding removal
    Donating Users mystic231's Avatar
    Michigan
    No idea so I checked my Factory service manual. It says:
    1. Remove the rocker finish panel to fender screws.
    2. Remove the rocker finish panel to rear quarter screws.
    3. Use a heat gun 6 inches from the surface to heat the molding.
    4. Hold the heat gun approximately 6 inches from the surface.
    5. Apply the heat for approximately 30 seconds using a circular motion.
    6. Use a small plastic flat-bladed tool to remove the rocker finish panel from the panel surface.
    7. Remove the rocker finish panel from the support panel.
    8. Remove the rocker finish panel support nuts from the studs.
    9. Remove the rocker finish panel support from the vehicle.
    In reading the installation procedure it appears to be glued to the body:
    Push the molding inward to fully seat the molding into the support and ensure a maximum bond of adhesive to body.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: rocker moulding removal
    Moore, Oklahoma
    no, its taped on with 3M
    Shawn W. Larsen
  1. Rocker Rust-HELP
    By Mad Monkey in forum Visual/Body Modifications
    Last Post: 08-31-2009, 11:37 AM
  2. rocker panels
    By The1AndOnlyBug in forum 5.3L V8 (LS4)
    Last Post: 07-22-2009, 08:07 AM
  3. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
  4. rocker panels
    By razoredge in forum Visual/Body Modifications
    Last Post: 11-27-2008, 07:50 PM
  5. Rocker rust
    By MichEE in forum Visual/Body Modifications
    Last Post: 09-10-2008, 11:28 AM
