Thread: What controls the key fob???
Results 1 to 8 of 8
palmergg What controls the key fob??? 07-16-2009, 10:17 PM
minichopper6hp Re: What controls the key... 07-16-2009, 11:47 PM
mystic231 Re: What controls the key... 07-17-2009, 07:15 PM
palmergg Re: What controls the key... 07-18-2009, 05:55 PM
Liquifire Re: What controls the key... 07-19-2009, 05:27 PM
palmergg Re: What controls the key... 07-19-2009, 10:29 PM
Liquifire Re: What controls the key... 07-20-2009, 12:27 AM
palmergg Re: What controls the key... 07-24-2009, 10:22 PM
  1. #1 What controls the key fob???
    Aug 2008
    Ohio
    I have been having some ongoing issues with 98 gp after an unintended visit to water filled ditch in February. Rght now the remote is not working. I reprogrammed it to my 99 Regal and it worked--to some extent. Anyway, it appears the remote is not my issue, any suggestions on where to go next?
  2. #2 Re: What controls the key fob???
    Banned - Busted For Scamming
    Feb 2009
    The bcm controls the key fob
  3. #3 Re: What controls the key fob???
    Donating Users mystic231's Avatar
    Michigan
    The battery may be going dead in the keyfob. One of mine did for the '98 so now I'm using the other one.
    So what kind of issues with the car or is it just fob related?
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: What controls the key fob???
    Aug 2008
    Ohio
    Replaced BCM, Airbag Control Module, all fluids twice. Ended up having to replace tranny, headlights, fogs. The remote is not a big deal with all of this but just frustrating since the BCM was replaced. I may try programming my 1999 Regal's remote and see what happens...
  5. #5 Re: What controls the key fob???
    Wausau, WI
    replace fob battery and see what happens.......
  6. #6 Re: What controls the key fob???
    Aug 2008
    Ohio
    Did replace battery. I will try the Regal fob or a replacement and hope....
  7. #7 Re: What controls the key fob???
    Wausau, WI
    good luck......
  8. #8 Re: What controls the key fob???
    Aug 2008
    Ohio
    Programmed Regal fob and it worked fine. Bought 2 used fobs on 3bay so now I have spares. When I took the old one apart there was a pretty good accumulation of corrosion, crud, etc.
  1. 01 GT Fan Blower Controls Burned Out!?!?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 02-23-2009, 08:00 AM
  2. steering wheel controls
    By 52 picup in forum General Tech Discussion
    Last Post: 10-22-2008, 10:44 PM
  3. heater controls
    By e56505 in forum General Tech Discussion
    Last Post: 10-05-2008, 08:49 AM
  4. heater controls
    Last Post: 09-29-2008, 08:08 AM
