the climate control lights, the steering control lights, and the buttons on the doors lights are all out. which fuse should i look for because i couldnt find it or what color wire should i try to find thanks.
the car is an 06 gxp could this be from a wire when i put a new radio in
I'm only guessing because I haven't installed on a GXP, but sometimes there is a ground for interior lights on the radio harness. It is usually black and on some it will have a stripe on it. Like I said I am only guessing. I know on my 2000 there is a fuse for the interior lights but it is only for the dome lights not the steering wheel. You may also check the under hood relays for a lighting relay.
