Thread: Climate control problem
Results 1 to 11 of 11
  1. #1 Climate control problem
    SE Level Member LSXHP's Avatar
    Morris IL
    My GTP is a 99, problem I'm having is the climate control box (Dual climate control). When it displays the ext temp it keeps reading wrong. It will start at say 50* and slowly count up to the actual outside temp 1 degree at a time then begin to count down all the way to -39* and sometimes just stay there at which point its really say 90* out and my ac pump shuts off because it thinks its so cold out. This problem is intermminent but becoming much more common almost a daily thing lately. Any ideas on whats going on? I'm guessing either the climate control box itself is bad or where is the sensor that tells it what the outside temp is located at??
    On a side note my heated seat also intermintently quits working and dont seem to work much at all anymore and my HUD will get dim sometimes and then go dim then bright dim to bright over and over, could these all be related to a single problem?
    White 99 GTP-180*,FWI,ZZP Plog,3"DP.ZZP PCM, Magnaflow resinator.
    SOLD June 2009 Silver 2000 Z-28 383LSX Stroker, 10.94@122 N/A
    2004 Suzuki GSXR-750, lowered, Piped,filters,smoked screen
  2. #2 Re: Climate control problem
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    that is the sure tale sign that the temp sensor is on its last leg.
    This happened to be on my 2k replaced sensor and all was good
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Climate control problem
    Morris IL
    Quote Originally Posted by Toofastgs View Post
    Where is the sensor located, whats it look like?
  4. #4 Re: Climate control problem
    Morris IL
    Anyone??????
  5. #5 Re: Climate control problem
    Morris IL
    wow nobody knows where this thing is huh.....does it even exist?
  6. #6 Re: Climate control problem
    Wausau, WI
    It does exist.......I dont know on this vehicle, but on other GM's I have owned it was in front of the radiator.....sorry I can't be of any real help.
  7. #7 Re: Climate control problem
    Hamilton, Ontario
    I replaced mine and it is on the main cross member infront of the rad.
  8. #8 Re: Climate control problem
    Morris IL
    Thanks whats it look like and the exact name of it so I can go pick one up?
  9. #9 Re: Climate control problem
    Morris IL
    anybody home?
  10. #10 Re: Climate control problem
    Donating Users mystic231's Avatar
    Michigan
    Might want to give Ed Morad a call. He should be able to fix you up for MUCH less.
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    I've had excellent service from Ed and he's saved me hundreds of bux.
    Your signature says you sold the GTP. Whas sup?
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  11. #11 Re: Climate control problem
    Wausau, WI
    Quote Originally Posted by mystic231 View Post
    +1 for morad or a local junkyard.........don't know the exact term for it other than the outside temp sensor...........
    it says sold on the same line as the z28, so that is what i guess is sold....
  1. Climate control issues!
    By OmegaRyan in forum General Tech Discussion
    Last Post: 12-26-2010, 10:01 PM
  2. Digital CLimate control
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 10-15-2009, 08:01 AM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. climate control
    Last Post: 01-27-2009, 09:10 PM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
