Thread: clunking
Results 1 to 7 of 7
  1. #1 clunking
    Donating Users
    Plainfield, IL
    hey guys so when i go down curbs or hit speed bumps at slow speeds i notice a clunk noise....i thought it was loose cradle bolts so i tightened them and its still there....i had my cradle dropped by a shop recently and i was wondering do you guys think this noise could be caused by loose motor/tranny mount bolts? i also have poly upper mounts but i dont see them causing this clunk noise and it sounds like its coming from under the motor...whats your insight on this?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: clunking
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Exhaust. I dont know about under the motor, but I had somthing similar, and it was a broken exhaust hangar.
  3. #3 Re: clunking
    TDCRacing
    Guest
    Strut mounts? Ball joints?
  4. #4 Re: clunking
    Donating Users
    Plainfield, IL
    i had to drill out an orignal ball joint and put in a new one with bolts..maybe thats loose?
  5. #5 Re: clunking
    Jan 2009
    connecticut
    I had a clunking noise when going over speed bump and certain other bump, it turned out to be the control arm bushings.
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  6. #6 Re: clunking
    Donating Users
    Plainfield, IL
    just so happens one of mine are ripped lol can you change the one toward the front of the car without new control arms? i think the ones im talking about are the upper ones...
  7. #7 Re: clunking
    Jan 2009
    connecticut
    Yeah mine was the upper one too, you can get just the bushing, i did, it was i like $25-ish. I had a buddy of mine do it so i'm not sure how hard it is to change.
  1. clunking noise when i go over unlevel ground
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 07:16 PM
  2. Odd issue... Pop/Clunking sound shifting into 2nd OR braking hard...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-09-2009, 10:28 PM
  3. clunking
    By QwikGT in forum Brakes/Suspension/Chassis
    Last Post: 03-06-2009, 08:30 PM
  4. Loud Clunking coming from rear left
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2008, 10:16 PM
