Thread: fog lights
Results 1 to 5 of 5
  1. #1 fog lights
    Apr 2008
    A while back my drl and fog lgihts stopped working. i dont mind that the drl no longer work but i want my fog lights back. I looked at the fuses and they all looked good. i have the hids and i tried to switch back to my stock light and they still didnt work. Where should i look next?
  2. #2 Re: fog lights
    Wausau, WI
    did you check the relay for this as well.........I don't know where it is off hand. Does the fog light switch light come on on the dash? Is there voltage at the fog lights or the DRL light locations?
  3. #3 Re: fog lights
    Houston, TX for now
    I believe there is an additional fuse or relay under the hood on the driver side by the air cleaner.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  4. #4 Re: fog lights
    Apr 2008
    the light on the switch does come on i will hopefully get to check to see if there is voltage tomarrow.
  5. #5 Re: fog lights
    Wausau, WI
    as we all know............no voltage=no worky
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Fog lights
    By Dohner in forum Shops and Community Heroes
    Last Post: 05-26-2009, 05:05 PM
  3. Fog Lights
    By jg2000gtp in forum General Tech Discussion
    Last Post: 01-27-2009, 07:39 PM
  4. ABS and TCS Off lights are on
    By 03GTPFour in forum General Tech Discussion
    Last Post: 04-23-2008, 10:10 AM
