Thread: 9 psi on a stock pulley...video
Results 1 to 20 of 26
  1. #1 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    in my previous thread i said i pushed 9 psi at the top ends of the rpms on a 3.8 stock pulley...here's the vid
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: 9 psi on a stock pulley...video
    Wausau, WI
    do you have the u-bend to v-bend backpressure upgrade?
    Does it feel like it is pulling hard?
  3. #3 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    yeah it pulls pretty hard for being un tuned....i have headers that go into a 3 inch straight downpipe...no u-bend
  4. #4 Re: 9 psi on a stock pulley...video
    Am I cross-eyed or did it touch 10?
  5. #5 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    it almost touches ten about 9.5
  6. #6 Re: 9 psi on a stock pulley...video
    in a house
    Quote Originally Posted by gotboost3 View Post
    Thats not good on a stock pulley. You better get some rockers or cam when you throw that 3.4 on or knock..knock. Maybe its just a freak lol Doesnt seem like its flowing to well
  7. #7 Re: 9 psi on a stock pulley...video
    Quote Originally Posted by silverstreak View Post
    He has headers...and a FWI...it flows just fine
  8. #8 Re: 9 psi on a stock pulley...video
    in a house
    Oh he has headers, well that changes everything. lol
  9. #9 Re: 9 psi on a stock pulley...video
    May 2008
    staten island,NY
    its boost stacking. this isnt a twin screw blower, its a roots...you want as much air flowing as possible. rockers or a cam are needed in this situation before the piston breaks off some chips like a bag of lays. the 3800 wants less boost with smaller pulley!!! hope this helps
  10. #10 Re: 9 psi on a stock pulley...video
    Donating Users blowfishRus6's Avatar
    g.a.
    stock heads cant flow crazy amounts of air. i could see it happening close to redline. rockers might be a good investment.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  11. #11 Re: 9 psi on a stock pulley...video
    Jan 1970
    Maquoketa, Iowa
    Weak... lol kidding.
    I wouldn't worry too much about boost levels on a roots blower unless your degrees of knock is the same as your boost level.
  12. #12 Re: 9 psi on a stock pulley...video
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by blowfishRus6 View Post
    Correction: Stock heads HAVE flowed some crazy amounts of air before just fine.
  13. #13 Re: 9 psi on a stock pulley...video
    g.a.
    yea i ment to retype that when i did it, stock heads combined with stock cam.
    up top it dont seem like it can keep up with flow. i dont hit max boost till 5k plus also.
    its slow.
  14. #14 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    so am i ok im not knocking at all the kr is being scanned right above the boost gauge i dont get any kr until i get to about 80 and then i knock which should disapate with a tune.....so is this bad or no? im not knocking at all on that pull you just watched....is it a factory freak?
  15. #15 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    couldnt i just heighten my BBV to bleed a lil more before shifts...?
  16. #16 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    seems kinda iffy that stock heads with headers cant flow the boost produced by a 3.8 pulley.....if stock heads cant flow these small numbers thats weak sauce lol and as the psi goes up i feel a lil more pull.....so isnt the boost going to good use then?
  17. #17 Re: 9 psi on a stock pulley...video
    in a house
    If your not knocking when you put the 3.4 on then boost away brother. 9.5 on a stock pulley just seems like alot especially since you have headers but if you have no KR then who cares.
  18. #18 Re: 9 psi on a stock pulley...video
    Banned - Busted For Scamming
    Feb 2009
    Do you have a ported blower/lim? That would probably take care of that.
  19. #19 Re: 9 psi on a stock pulley...video
    I think since he has headers a tune would be a better option at this point.
  20. #20 Re: 9 psi on a stock pulley...video
    Donating Users
    Plainfield, IL
    i have 0 KR....so i guess im good and just lucky...
  1. stock pulley 99% of time, 3.4 for 2 track days per year?
    By hockeymaniak88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 08:26 AM
  2. Can I run a 3.4 pulley on a stock gtp?
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 11:25 AM
