Thread: Autolite 104s
Results 1 to 15 of 15
Bigbm80 Autolite 104s 07-14-2009, 08:41 AM
blueguy Re: Autolite 104s 07-14-2009, 11:07 AM
Bio248 Re: Autolite 104s 07-14-2009, 12:03 PM
Bigbm80 Re: Autolite 104s 07-14-2009, 02:17 PM
gotboost3 Re: Autolite 104s 07-14-2009, 02:24 PM
TheOtherNick Re: Autolite 104s 07-15-2009, 09:22 PM
Guest Re: Autolite 104s 07-15-2009, 09:23 PM
Bigbm80 Re: Autolite 104s 07-15-2009, 09:24 PM
Guest Re: Autolite 104s 07-15-2009, 09:28 PM
Bigbm80 Re: Autolite 104s 07-15-2009, 09:31 PM
TheOtherNick Re: Autolite 104s 07-15-2009, 09:35 PM
Bigbm80 Re: Autolite 104s 07-15-2009, 09:42 PM
Guest Re: Autolite 104s 07-15-2009, 09:52 PM
TheOtherNick Re: Autolite 104s 07-15-2009, 09:52 PM
Iron Indian Re: Autolite 104s 07-16-2009, 09:43 PM
  1. #1 Autolite 104s
    SE Level Member Bigbm80's Avatar
    Feb 2009
    Princeton NJ
    I just bought a set of Autolite 104s and when I bought them online I forgot to see if they were specifically for my grand prix, so does anyone know if I have to gap them and if so whats the gapping? Thanks!
  2. #2 Re: Autolite 104s
    What are your mods? Probably try to gap them around .050"-.060"...
  3. #3 Re: Autolite 104s
    i gapped mine at .052 because i was trying to run a lot of boost, but youd probably be okay with .055 or so.
  4. #4 Re: Autolite 104s
    Feb 2009
    Princeton NJ
    As far as mods go I have a cold air intake, 3.4 pulley, 3" downpipe with a high flow cat and u-bend and resonator delete, and flowmaster mufflers.
  5. #5 Re: Autolite 104s
    Donating Users
    Plainfield, IL
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  6. #6 Re: Autolite 104s
    Charles City, IA
    Even if the plug says it is exactly for your car you need to check the gap. You never now if it has been dropped or what not. I run mine at .054
    SMGPFC Two Nipple General
  7. #7 Re: Autolite 104s
    TDCRacing
    Guest
    .055 with those mods
  8. #8 Re: Autolite 104s
    Feb 2009
    Princeton NJ
    01GTP you make a very could point, I guess .054 or .055 it is, does .001 really make a difference?
  9. #9 Re: Autolite 104s
    TDCRacing
    Guest
    Quote Originally Posted by Bigbm80 View Post
    Nope. You want the biggest gap that you can run without having spark blow out. That's why everyone is always closing the gap when they increase the boost. To try to help prevent this from happening. But the bigger the gap you can run the better. Typically it gives a smoother idle along with a cupple other things
  10. #10 Re: Autolite 104s
    Feb 2009
    Princeton NJ
    O, alright. I plan on getting bigger ignition wires in the near future will that effect anything?
  11. #11 Re: Autolite 104s
    Charles City, IA
    Maybe a little. You just have to see what you can run. If you have a scanner you can keep opening up the gap till you start to miss. Then just back it down. I have not taken to the time to see what i could run. I just decided to go with .054-.055 and it has worked fine for me
  12. #12 Re: Autolite 104s
    Feb 2009
    Princeton NJ
    Sounds good, Thanks a lot you all have been a big help!
  13. #13 Re: Autolite 104s
    TDCRacing
    Guest
    Not a problem
  14. #14 Re: Autolite 104s
    Charles City, IA
    No problem
  15. #15 Re: Autolite 104s
    Moore, Oklahoma
    I ran .054 without any issue on my white car (when it had a few bolt ons), I still run this plug and that same gap on my black GTP though.....
    Shawn W. Larsen
  1. Autolite 605's or 104's
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 08:19 PM
  2. My autolite 104's are bad???
    Last Post: 07-03-2008, 03:30 PM
