Thread: Is it new MAF sensor time?
Results 1 to 7 of 7
  1. #1 Is it new MAF sensor time?
    SE Level Member dhall9's Avatar
    OKC
    I've been getting the P0102 code for a couple of weeks now. I've checked the harness, nothing lose. I've cleaned the MAF really well with CRC MAF cleaner and today the light came back on. So I'm thinking it is time to replace the MAF. I just thought I'd throw it out there and see if someone has any other ideas before I drop some cash on a new MAF.
    2002 GTP Coupe - Motosports CAI, 3" ZZP DP, GMPP sway bars, ZZP Front & Rear STB's, AL 104's, 180* Tstat
  2. #2 Re: Is it new MAF sensor time?
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by dhall9 View Post
    You might see if there is another member close by that would be willing to swap MAF's to see if yours truly is kaput - pretty quick, easy and safe test. But, you've done everything else I would have suggested to try and remedy it to this point...sounds like it's bad.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  3. #3 Re: Is it new MAF sensor time?
    Moore, Oklahoma
    Quote Originally Posted by Swash View Post
    -Swash
    Speaking of that, i'm in OKC, your in OKC and I do have a spare MAF I use for testing if you need one to borrow for a day or two.
    How often does this code reappear?
    Shawn W. Larsen
  4. #4 Re: Is it new MAF sensor time?
    Or you can just unplug it too...if it changes anything then it is the MAF.
  5. #5 Re: Is it new MAF sensor time?
    Hoffman/Schaumburg, IL
    Not always true, Mine actually ran worse with the maf unplugged.... The more modded you are, if you don't have a PE tune, the car might not even run w the maf unplugged(mine didn't).... Swapping with a knonw good one is the only way to know for sure
  6. #6 Re: Is it new MAF sensor time?
    OKC
    A new one will be here today, thanks for the offer though
  7. #7 Re: Is it new MAF sensor time?
    chicopee Ma.
    68 bucks from rockauto for a MaF i just bought and it was an AC delco also
  1. CAT or O2 Sensor
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2009, 04:18 PM
  2. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  3. Iat sensor ?
    By GTP4 in forum PCM Tuning
    Last Post: 10-18-2008, 11:14 AM
  4. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
  5. MAF Sensor
    Last Post: 06-13-2008, 02:57 AM
