Thread: ZZP S/C Spacer Question
Results 1 to 12 of 12
  1. #1 ZZP S/C Spacer Question
    Chicago
    I was thinking of buying a 1" supercharger spacer from ZZP. I was wondering if its worth it or not.
  2. #2 Re: ZZP S/C Spacer Question
    Charles City, IA
    Nope Read the thread called safely modding your 3800 and it will tell you every thing you need to know.
    SMGPFC Two Nipple General
  3. #3 Re: ZZP S/C Spacer Question
    Chicago
    I didn't see anything bout s/c spacer
  4. #4 Re: ZZP S/C Spacer Question
    Donating Users Liquifire's Avatar
    Wausau, WI
    throttle body spacer???
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  5. #5 Re: ZZP S/C Spacer Question
    in a house
    Quote Originally Posted by SloEvil View Post
    Unless your planning on using it to run meth. If your just thinking of buying it to keep the supercharger cooler then its a waste of money IMO.
  6. #6 Re: ZZP S/C Spacer Question
    Because it sucks.
    Quote Originally Posted by Liquifire View Post
    Sucks even more
    Quote Originally Posted by silverstreak View Post
    you want to spray meth before the blower anyways to cool the intake charge for the boosted air IMO.
  7. #7 Re: ZZP S/C Spacer Question
    in a house
    I think running it post blower makes more sense but I dont think the op wants the spacer for this reason anyways.
  8. #8 Re: ZZP S/C Spacer Question
    True dat...I gotcha fasho
  9. #9 Re: ZZP S/C Spacer Question
    Chicago
    I have a snow performance meth kit but havent installed it yet
  10. #10 Re: ZZP S/C Spacer Question
    Banned - Busted For Scamming
    Feb 2009
    depends on what you want really. The spacer will serve two purposes in your case, a place for the meth to tap into, and to isolate the heat from the engine to your blower.
    Whatever you do, dont buy zzp's overpriced crap. I sell a better product for less... you can check it out here.
    http://www.grandprixforums.net/f49/p...cer-17421.html
  11. #11 Re: ZZP S/C Spacer Question
    Chicago
    is that spacer 1"
  12. #12 Re: ZZP S/C Spacer Question
    Feb 2009
    why yes it is
  1. How to remove TB spacer, attached with RTV
    By 04CompG in forum General Tech Discussion
    Last Post: 06-21-2009, 03:22 PM
  2. S/C spacer?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 09:09 PM
  3. wood IC spacer
    By 04DetroitLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 05:25 PM
  4. Engine Spacer question
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 12:13 PM
  5. TB spacer?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 06:43 PM
