Thread: LIM Gasket Causing Coolant in Cylinder?
Results 1 to 17 of 17
  1. #1 Re: LIM Gasket Causing Coolant in Cylinder?
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by hesersypb View Post
    I do have the 3.8L. I am going to pick up a manual to make sure I do the Torque Specs correctly. I probably wont tear down the front bank since apparently I didnt need to tear the rear head off. I will check compression though. Hopefully it is the LIM Gasket. Hate to waste all this time for a bad engine.
    No need to buy a manual for the torque specs:
    CLICK ME
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  2. #2 Re: LIM Gasket Causing Coolant in Cylinder?
    Feb 2008
    San Diego, CA
    It could be the lower intake manifold (LIM) gaskets. As has been said, factory LIM gaskets were a nylon material. That nylon will fail in 100% of cases, it's just a matter of time. Replace those with the newer aluminum type, which can be gotten at a dealer or through online sources like ZZPerformance.com or intense-racing.com.
    (Don't get FELPRO "updated" style LIM gaskets; they're still nylon)
    It could also be the plastic upper intake manifold (UIM) itself (or the UIM gasket) . Over by the throttle body (TB) end, coolant flows up from the LIM, through the UIM gasket, into the UIM, through the TB, back through the UIM and UIM gasket, back into the LIM. All the while it flows around the EGR stovepipe coming into the UIM from the LIM. The UIM plastic in that area (and sometimes the UIM gasket also) melts/warps/cracks, allowing coolant ingestion. The plastic face where the TB attaches also can warp from heat, allowing coolant ingestion at the TB gasket.
    Best easy/cheap fix for that is the Auto Parts Now (APN) replacement UIM kit, which comes with new UIM gasket, TB gasket, and a steel-sleeved EGR passage in the UIM and a special reduced-diameter EGR stovepipe for the LIM (these last items reduce the long-term tendency toward plastic meltage in that area).
  1. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  2. Why is my MAP sensor causing my car not to start?
    By 1998gpgt in forum General Tech Discussion
    Last Post: 05-11-2008, 06:20 PM
  3. Hesitation causing poor gas mileage
    By elriqo28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 12:23 PM
  4. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
  5. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
