Thread: clicking sound under dash
Results 1 to 12 of 12
CTKGP09 clicking sound under dash 05-20-2009, 04:26 PM
Golgo13 Re: clicking sound under dash 05-20-2009, 06:23 PM
CTKGP09 Re: clicking sound under dash 05-20-2009, 06:34 PM
Golgo13 Re: clicking sound under dash 05-20-2009, 06:38 PM
CTKGP09 Re: clicking sound under dash 05-20-2009, 06:55 PM
taximech Re: clicking sound under dash 06-21-2009, 09:41 AM
Lawngoose Re: clicking sound under dash 06-21-2009, 12:45 PM
CTKGP09 Re: clicking sound under dash 06-21-2009, 10:42 PM
popeyenate Re: clicking sound under dash 06-30-2009, 09:37 AM
Lawngoose Re: clicking sound under dash 06-30-2009, 10:38 AM
popeyenate Re: clicking sound under dash 07-02-2009, 07:13 PM
popeyenate Re: clicking sound under dash 07-15-2009, 01:04 PM
  1. #1 clicking sound under dash
    Willoughby, Ohio
    whenever i turn on my heat/AC/or just cool air, there is a clicking sound comming from under the passenger side dash board...it sounds like a fan rubbing against something but air still flows thru the vents...it doesnt matter wut temp or which vents r blowing the air, the clicking is ALWAYS there when i have the fan on...wut is this and is it hard to fix???
    n i aplogize for me posting things in wrong places ha
  2. #2 Re: clicking sound under dash
    Oct 2008
    mascoutah, Il
    sounds like you need a new blower motor.
    remove the cloth kick panel under the passenger side dash the blower motor can be seen once you do this remove screws and replace
    2002 GTP
    custom HOK paint
  3. #3 Re: clicking sound under dash
    Willoughby, Ohio
    hmm ok ill check it out.... is there n e othere ideas as to wuts wrong b4 i replace something i might not need to? i wanna consider all possibilities
  4. #4 Re: clicking sound under dash
    Oct 2008
    mascoutah, Il
    Well, if you take it out and look at it and it wobbles or has rubb marks on it you'll know for sure. Not a hard or too expensive thing to replace.
    Please let me know what you find.
    2002 GTP
    custom HOK paint
  5. #5 Re: clicking sound under dash
    Willoughby, Ohio
    ok ill do that thanks
  6. #6 Re: clicking sound under dash
    Ocoee, Florida
    Sounds to me you have a blend door actuator going bad. Can you change the temp from cold to hot? I replace those actuators all the time on Crown Vics, I work on cabs.
  7. #7 Re: clicking sound under dash
    Outer Space
    A relay was making a clicking noise when my ignition switch was going bad. However, I also lost 1-4 on my A/C until I replaced it.
    02 GTP 13.6 @ 100mph - SOLD
  8. #8 Re: clicking sound under dash
    Willoughby, Ohio
    yep i put a new resistor in bc i lost 1-4 and eventually 5
  9. #9 Re: clicking sound under dash
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    i hear a clicking sound sometimes, a/c doesnt have to be on..it also makes a slight grinding noise type thing...like the fuel pump whine, but on, off on off...but its not that, just strange sounds under the dash...my dic/radio lights are out so i guess i have to chase a fuse...lol
  10. #10 Re: clicking sound under dash
    Outer Space
    popeyenate... if all fuses are fine... it sounds like you may be a victim of a bad ignition switch as well. I lost lights to my DIC when it was acting up.
  11. #11 Re: clicking sound under dash
    Jan 2009
    san diego
    you know what, i probably am...im having issues with my btsm and key coming out when in park. slamming the key into the cylinder used to work...shifting out and in of park used to work too...so maybe i created my own fate there years ago when key started sticking..but then it stopped for a couple years, then it started again few months before i left for depolyment. last time i had too much weight on teh keys, so i got keychain where you can detatch keys..that worked for 2 yrs..now what? lol...replace it i guess. so yes, i will check fuses, been too busy with duty and a day and half off to check it..on leave for 8 days now!!
  12. #12 Re: clicking sound under dash
    Jan 2009
    san diego
    well, checked out all the fuses that had anything to do with it, all seemed fine and still shorted...so i guess its time to replace it..and buy a new one!!
  1. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  2. clicking sound under dash
    By CTKGP09 in forum General Tech Discussion
    Last Post: 06-23-2009, 08:05 PM
  3. S/C Sound
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 11-18-2008, 10:33 PM
  4. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
  5. Squeaking/clicking in dash, climate control?
    By jagamite in forum General Tech Discussion
    Last Post: 10-21-2008, 11:05 PM
