Thread: AC Overcharged?
Results 1 to 4 of 4
patrickd AC Overcharged? 07-15-2009, 07:29 AM
minichopper6hp Re: AC Overcharged? 07-15-2009, 10:59 AM
JJ91284 Re: AC Overcharged? 07-15-2009, 11:05 AM
minichopper6hp Re: AC Overcharged? 07-15-2009, 11:08 AM
  1. #1 AC Overcharged?
    Michigan
    The other day I noticed my AC wasn't very cold. I put in 1 small can of 134 refrigerant. Now the recirculation, Max Ac cycles from Max to Reg AC back and forth. Is it possible that I have overcharged my system with only 1 can of 134?
    Will it stop taking refrigerant through the suction side when full or will it keep taking till overfull?
  2. #2 Re: AC Overcharged?
    Banned - Busted For Scamming
    Feb 2009
    You can overfill it easy. How did you know it was low to begin with? Im not sure what you mean by cycling from max to reg a/c? Also, what year is your car?
  3. #3 Re: AC Overcharged?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Yep, very easy to overcharge A/C system, which can damage the compressor.
    He probably means he was turning the ac knob from normal ac position to max ac position and so forth.
    You should have bought one that has a pressure gauge at least on it. I know my hvac buddy when he does cars, he vacs the whole system out then adds the right amount via weight. My 97gtp still has ice cold ac and has never been charged once, but my friends 07 civic si a/c system was toast because he had a hole in his condenser.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  4. #4 Re: AC Overcharged?
    Feb 2009
    Stupid hondas
    Anyways, yes the only way you will know how much refrigerant you have in there is to count it as its going in. You should use the factory amount as a baseline and go from there, either adding or subtracting till you get the best results.
