Thread: a/c control
Results 1 to 5 of 5
stanggreg90 a/c control 07-08-2009, 01:31 PM
BoostedComp Re: a/c control 07-09-2009, 10:15 AM
SDGTP99 Re: a/c control 07-18-2009, 04:36 PM
ASCStinger Re: a/c control 07-27-2009, 08:29 PM
mystic231 Re: a/c control 07-27-2009, 10:07 PM
  1. #1 a/c control
    roselle
    i have a 2000 GT i was wondering if the dual a/c control will work in my car its out of a 2000 gtp i have the stock regular a/c controls in my car know
  2. #2 Re: a/c control
    GT Level Member BoostedComp's Avatar
    Youngstown
    i would wait for a more informative post to do or not do this... but i imagine its possible to do so... but might take some modifying as yous is wired for even flow while the dual climate would need seperate feeds for both sides?? i dont do much is the electrical stuff outside of helping people put in stereos but i just thought id ad my .02 for the time being.
  3. #3 Re: a/c control
    Wichita
    Most likely it wont work.
  4. #4 Re: a/c control
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    there's two connectors for the climate control in my 98gtp, the one is plugged in (i have the digital), but there's another connector of the same size and shape behind my glovebox door that's just laying around not plugged into anything. Just a guess that it's for the manual climate control, check behind your golvebox door to see if you have a second connector similar to the on that's plugged into your manual controls
  5. #5 Re: a/c control
    Donating Users mystic231's Avatar
    Michigan
    Anything is possible depending on your abilities and dedication and you would certainly want a factory service manual (available on E-Bay usually).
    The factory service manual seperates the manual A/C and the automatic A/C (option code CJ2) into seperate sections. In the automatic A/C section it says
    Most aspects of the refrigeration, heater, and air distribution systems are unique to vehicles equipped with a dual zone system.
    It looks like in the diagrams you'll be pulling most of the dash out to get all the componets into place. If you've got the time it looks doable.
    Automatic air is the biggest thing I miss on my 2002.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  1. Cruise Control
    By ohioGTP in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2009, 11:39 AM
  2. Boost Control?
    By RicerKiller in forum PCM Tuning
    Last Post: 04-29-2009, 08:55 AM
  3. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
  4. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  5. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
