Thread: 98 GTP Coupe-upgrade questions-exhaust
Results 1 to 20 of 21
  1. #1 Re: 98 GTP Coupe-upgrade questions-exhaust
    Wausau, WI
    so how much HP gains would I expect to see from the CAI, 3.4 pulley, and the Plog and downpipe changes( I already have 180 t-stat) and the tune? how much torque changes as well........I am just looking for approximate changes not exact numbers. Thanks.
  2. #2 Re: 98 GTP Coupe-upgrade questions-exhaust
    Quote Originally Posted by Liquifire View Post
    Quit thinking about the pulley. That is why I posted that thread up there...you got a bunch of mods to do before you safely drop a pulley size. CAI, Colder Plugs, Plug Wires, 3" DP, U-Bend Delete, Front Powerlog, OR Headers, and a tune.
    Then you can drop to a 3.5" or 3.4".
  3. #3 Re: 98 GTP Coupe-upgrade questions-exhaust
    Wausau, WI
    I am not thinking about doing the pulley until last, but I am thinking about doing it in time. I did read that entire 3800 upgrade thread before I started this thread. Since I did not realize exactly what exhaust components there were totally, and what each aftermarket piece replaced on the stock setup. That is why I started this thread to get more info and do the mods in the "proper order" before finally changing out the pulley and getting the aftermarket tune. I just wanted to know what type of HP gains I could possibly expect when I was all said and done with all of those changes(T-stat 180, PLOG, 3" downpipe w/ubend delete and high flow cat, CAI, Tune, and then pulley) I am just trying to see if it is worth the money to me to spend to get how much HP........Is it twenty HP or fiftyHP or what? I just would like a guesstimate of how much it will help in the HP department. Thank You
  1. Exhaust Upgrade
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2009, 12:38 PM
  2. upgrade for headlights on 96 gp coupe sealed beam
    By graham96gpse in forum Visual/Body Modifications
    Last Post: 10-01-2008, 07:28 PM
  3. A Few Quick Questions About Exhaust Tips..
    By blockbusted in forum General Tech Discussion
    Last Post: 08-21-2008, 01:44 PM
