Thread: Squeaking
Results 1 to 10 of 10
  1. #1 Squeaking
    Oct 2008
    Northern Illinois
    There's a loud and consistent squeaking noise coming form my front passenger wheel whenever I drive, any ideas?
  2. #2 Re: Squeaking
    Wausau, WI
    wheel bearing???? Brakes???? dust shield bent and rubbing on rotor area???
  3. #3 Re: Squeaking
    Outer Space
    i was thinking wheel bearing... but it shouldnt squeak... it could be bushings in suspension/sway bar ...etc.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: Squeaking
    Wausau, WI
    Quote Originally Posted by BwolfGT View Post
    by consistent do you mean non-stop while driving, or does it come and go while you are driving, but it still takes place every time that you drive?
  5. #5 Re: Squeaking
    Oct 2008
    Northern Illinois
    Its usually non-stop while driving except when I brake...but then the breaks squeal
    Sometimes it goes away but not often
  6. #6 Re: Squeaking
    Wausau, WI
    I would lean towards the wheel bearing. If it is the sway bar it should only make noise where it is bumpy or when turning. I assume it makes noise on a smooth road as well? At all speeds? does it change pitch with speed?
  7. #7 Re: Squeaking
    Oct 2008
    Northern Illinois
    It does make a different noise on bumps...kinda sounds like a broken mattress.
  8. #8 Re: Squeaking
    Wausau, WI
    struts or supports? I dont know though............if that is what it is I would think it would only be this way for bumps and turning as well.......not all the time.....but who knows, there have been stranger things happen.
  9. #9 Re: Squeaking
    Oct 2008
    Northern Illinois
    Yeah. I think I'm just gunna slowly replace the whole suspension, high miles its all bound to go at some point anyway
  10. #10 Re: Squeaking
    SE Level Member 200GpGt's Avatar
    Monclova
    I have the same problem but mine stops squeaking when i turn right, i think, but its a constant squeak, and its very annoying, i've changed my rotors and pads, but it still there. i hope its not the cv joint.
  1. squeaking noise
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2009, 03:03 AM
  2. how do you stop belt squeaking?
    By nemesis in forum General Tech Discussion
    Last Post: 12-14-2008, 01:10 AM
  3. squeaking sound?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 05:35 PM
  4. Squeaking/clicking in dash, climate control?
    By jagamite in forum General Tech Discussion
    Last Post: 10-21-2008, 11:05 PM
