no tyco stamp but I looked up the part number from the connector diagram and that's what I came up with.
I think I will try using the small one that you found since its all I've got. Its the HUD control signal wires so I could probably use a small gauge wire and be OK.
I like doing things the right way even if it is a a little more work. If the tabs I find don't work out, I'll probably go with just finding some other 5 or 6 pin connector and use that instead.
